I've had a couple of requests for the part numbers used in my 5.7 hemi swap into my 70 Barracuda so here's where I'm at so far;
TTI headers part #TTI 57HC-C4 $718
TTI engine mounts part #MM57BE $133
Charlies oilpan $400
XV Motorsports intake manifold part #11-2102 $499
MSD Hemi6 controller part #MSD-6013 $498.60 (Summit)
MSD Hemi6 wiring harness part #MSD-88863 $200 (Summit)(for carb application with early style coils)
SRT 6.1 Hemi cam & spring kit $189.99 (Henson Motorsports sells these on Ebay)
Taylor short plug wires, not sure of part #, usually sell on Ebay for $60
Those are the parts I've acquired so far. I'll be using a smallblock TF727, which bolts right up to the hemi. The 5.7 hemi 4 bolt flexplate will work if you have a machine shop cut the starter ring gear off of it (you use the ring gear on the 727 torque converter) and elongate one hole for the offset bolt on the converter, or you can use MP's flexplate part #P5153753. The oil filter will not work in the stock location and on the B&E bodies you can use the Jeep adapter part #53021610-AE if you can find one! If not, you can use a remote filter mounting kit (mandatory on A bodies) such as Summit's part #SUM-G4985 for $34.95. My 5.7 is from a 2003 Ram pickup, and I will be using the stock serpentine drive system with the stock accessories. The alternator can easily be wired for a stock Mopar electronic two wire voltage regulator, and I will have a new end crimped on the hemi power steering pressure line to fit my stock steering box. I will also be using the stock 5.7 clutch fan setup. If you don't want to use the A/C compressor you can get an A/C compressor delete pulley part #53032131-AA from Mopar. It's kind of pricey, but makes for a clean looking setup. If you don't plan on running power steering you can use a shorter Gates K70776 belt and move the lower idler pulley to the position below the A/C compressor to do away with the P/S pump. You will also have to run an electric fuel pump with the carb setup on the new hemi as there is no provision on the engine for a mechanical pump.
Post any questions you might have and I'll answer them best I can. I don't have any pics right now, but will try to post some with updates as I move along on this project.
