[quote author=392heminut link=topic=48028.msg499508#msg499508 date=1220239495
As for the starter, stop and think about it. If you are using a TF727 and the starter bolts to the TF 727 bellhousing then it stands to reason that the starter would work with the ring gear on the torque converter as originally designed. Also, the mini starters that are used on the 5.2 and 5.9 Magnum engines work just fine in this application. I
[/quote]
Sorry I should have clarified
I do not know if the 5.7 starter you have will work on the driver’s side 727 mounting location.
I also have the starter off a Hemi truck and wonder if its going to bolt up to the 727 and block and will it engage the ring gear mounted on the flexplate or converter? What starter are you using?
