Author Topic: some progress and some wondering  (Read 2032 times)
Offline RaptorF229
  • A work in Progress
« on: August 07, 2008 - 02:56:20 AM »
ok so I decided do do some electrical stuff. I started off by putting on a new transmission neutral/safety harness on. That went quick and works. Then I decided to work on the overhead console. I got the seat belt and low fuel light to work the way it should. I couldn't get the door ajar light to work because I'm missing the switches. If anyone has some switches to spare pleas let me know. Now comes the frustration. I have two problems. One when I turn on my headlights my right signal comes on and stays solid and won't blink. When the headlights off the signal works fine. Another problem is none of my instrument  lights work. I changed the bulbs and the fuses with no luck. any suggestions on how to trouble shoot these problem?
Re: some progress and some wondering
« Reply #1 on: August 07, 2008 - 04:54:22 AM »
grounds , the headlights have a black harness that bolts onto the rad wall beside the battery where the extra wire from the battery also grounds to
, the turn signal socket may also need to be properly grounded , same thing with the dash lights , you need to have the cluster & the light panel grounded to work
Offline Aussie Challenger
« Reply #2 on: August 07, 2008 - 08:46:06 AM »
   :iagree:  More problems occur because of poor grounds, make sure your wiper switch is properly grounded also or the wipers won't "park" You should consider using relays for your head lights to remove the heavy load from the headlight switch.   :bigsmile:   :cheers:
Offline RaptorF229
« Reply #3 on: August 07, 2008 - 10:54:42 AM »
ok I'll start checking that later today. Thanks guys.
Offline RaptorF229
« Reply #4 on: August 07, 2008 - 08:15:58 PM »
ok the light panel isn't grounding. How should I fix this problem.
Offline RaptorF229
« Reply #5 on: August 07, 2008 - 09:15:41 PM »
I got the light panel to work. Still no change with the turn signal headlight problem. I checked the radiator mount ground. I cleaned it and no fix. I also disconnected the ground and the checked the light. It still did it with no ground connected.
« Reply #6 on: August 07, 2008 - 09:25:47 PM »
Problem with the turn signal could be a bad bulb, there are two filaments & if one is broken & shorted to the other then it acts as single circuit so when when you turn on your headlights the power is sent back through the turn signal wiring lighting up your indicator.
Offline RaptorF229
« Reply #7 on: August 07, 2008 - 09:30:06 PM »
which bulb ?
« Reply #8 on: August 07, 2008 - 09:34:09 PM »
It would be either the front valence(guess a 70 cuda it's in the grill) or rear tail lamp...the ones that flash when the turn signals are activated.
Offline RaptorF229
« Reply #9 on: August 07, 2008 - 09:44:47 PM »
ok I'll check. Thanks
« Reply #10 on: August 07, 2008 - 10:02:01 PM »
  Do you have a negative lead from the battery going to the body, I have fitted a lead to the front radiator panel as well as to the motor. Make sure that the ground wire makes contact with bare metal.   :cheers:
Offline RaptorF229
« Reply #11 on: August 07, 2008 - 10:38:31 PM »
The bulb did the trick. Thanks so much guys. Oh and I have the negative going to the engine and the starter relay. Should I ground it to the body too?
« Reply #12 on: August 07, 2008 - 11:32:55 PM »
the neg battery cable should be on the engine , the start relay doen`t need a ground
Offline RaptorF229
« Reply #13 on: August 07, 2008 - 11:42:58 PM »
  ok I'll move the one on the relay to the body
