If your running 14" rims you have very little to chose from, in 15" there are a few good options other than the reproduction bias tire that I would only recomend for a show car.. If your going to be driving much at all you want radials.. B.F Goodrich Radial T/A seems to be what most folks settle on, Goodyear & Firestone both have a white letter radial & there are some good tires in lesser known slightly less expensive brands such as Cooper & Kelly which I have had good results with both. It will be about impossible to get the OE sizes, mine came with F70/14s roughly a 205/70/14 or 215/70/15. Id suggest something more on the line of a 235/60 for looks, handling & availability
