Author Topic: 383 mild upgrades is 135 compression in all cylinders about right  (Read 476 times)
Offline geneo4116
  • 70 rt 383 auto blk/blk apprx 450hp
 :wavingflag: :wavingflag: :wavingflag:135 compression is that about right for 70 383
Re: 383 mild upgrades is 135 compression in all cylinders about right
« Reply #1 on: August 07, 2008 - 11:55:12 PM »
lots if variables , but yes it is in the range ,
 if the engine is hot & the throttle is held open the readings may rise , , how fast is the engine cranking over Etc , what is the pressure on the first hit ?
 I use a guage as more of a comparitive tool , if all cylinders are in the 15% range , less is better the engine is healthy
