Author Topic: Question about lifters  (Read 490 times)
Offline 71chmark
« on: August 08, 2008 - 11:18:15 AM »
My old lifters (stock hydraulic) have sat about 12 years so I figured I'd change them while I have the heads off.  The new ones are also stock and I can compress them against the spring a little although I can't compress the old ones any.  I assume they will pump up a after I run the motor. Is this right?  I suppose when I set my adjustable roller rockers I'll have to be careful not to compress the springs in the lifters to get an accurate setting? It seems like I should be able to squeeze the oil out of the old ones.  I have heard of anti-pump up lifters.  I guess my question is how do hydraulic lifters work and is there anything wrong with my assumptions?
I may be schizophrenic,
Offline 71chally416
    • The Streetwalker
Re: Question about lifters
« Reply #1 on: August 08, 2008 - 11:37:26 AM »
Soak them in a can of oil for a few hours before you put them in. They will pump up the rest of the way when you start the car so don't be concerned if they clatter for a while.
Offline r15303
« Reply #2 on: August 08, 2008 - 04:52:46 PM »
 :popcorn:
