Author Topic: Cam lobe wear  (Read 31722 times)
Offline 422STROKER
  • Member Since 6/3/06
Re: Cam lobe wear
« Reply #120 on: October 25, 2008 - 09:18:16 AM »
How about a thicker headgasket?
Tom :dunno:
Tom
Offline hemiken
Re: Cam lobe wear
« Reply #121 on: October 25, 2008 - 10:45:07 AM »
Hey BC,
Go to this site and type in your engine numbers and it will tell you your compression buddy.
http://www.csgnetwork.com/compcalc.html
If you need a hand with sizes just ask back here  :2thumbs:
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Re: Cam lobe wear
« Reply #122 on: October 25, 2008 - 12:17:21 PM »
He gives me NaN, maybe you can try hemiken. Bore 4,360, stroke 3,750, 78 cc head, pistons +5cc, felpro headgasket, 0 deck.
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Re: Cam lobe wear
« Reply #123 on: October 25, 2008 - 12:22:39 PM »
Tom :dunno:
What worries me moore Tom is that the excellent machineshop didn't do the intake, so the guy bought the heads from McCandless milled
and ready and jsut bolted them on to the shortblock he got from the other place.
Offline 422STROKER
Re: Cam lobe wear
« Reply #124 on: October 25, 2008 - 12:28:08 PM »
What felpro headgasket do you have?  You need the compressed thickness to calculate C.R.
Tom
Are you worried that the intake won't fit if you make it thicker?
Tom
Offline 422STROKER
Re: Cam lobe wear
« Reply #125 on: October 25, 2008 - 12:39:29 PM »
I come up with 10.91 with a .039 head gasket.
If you use a thicker one say .080 it is under 10-1.
Tom
Used this one.
http://www.rbracing-rsr.com/compstaticcalc.html
Tom
Offline 71chally416
    • The Streetwalker
Re: Cam lobe wear
« Reply #126 on: October 25, 2008 - 12:51:06 PM »
A competent machinist will just mill the Intake face on the heads to compensate for any block deck or head milling done.  That way you can still bolt any Intake on and you won't end up with a manifold that only fits one motor.
Offline Supercuda
Re: Cam lobe wear
« Reply #127 on: October 25, 2008 - 12:57:32 PM »
I took another look at the instruction sheet for my rings, and found the identification in the middle of the page! The bright one is the top ring, and the dark one the second. Bevels or dot markings go to the top, and stepped rings get the step on the bottom side (smaller diameter down). How is gasoline in your area? That will be what setermines what compression ratio you can get away with.
Re: Cam lobe wear
« Reply #128 on: October 25, 2008 - 01:27:24 PM »
I planned to use the ones in the big gasketset, don't have a partnr alone. Gasoline here is 95-98 octane but people over here say it's not better then yours. Supercuda, I got the rings right  :2thumbs: 71chally416, I suppose McCandless did what you said, I noticed no problem when I swapped cam.
Checked the felpro gasket, it's 0,044 uncompressed and piston to deck is 0,022.
« Last Edit: October 25, 2008 - 02:06:27 PM by Belgium Cuda »
Offline 422STROKER
Re: Cam lobe wear
« Reply #129 on: October 25, 2008 - 04:30:59 PM »
Yeah so you got the one that is .039 compressed, You will be pushing it on pump gas unless you have a big cam to bleed off cylinder pressure.  There are a few companies out there with thicker gaskets you can use to lower your compression, also there are a couple thickness intake gaskets out there too.
Tom
Tom
Re: Cam lobe wear
« Reply #130 on: October 25, 2008 - 04:54:08 PM »
I will use the Engle K56 in this one. Here is some pics from todays work.
Offline LAA66
Re: Cam lobe wear
« Reply #131 on: October 25, 2008 - 06:44:40 PM »
 You don't mess around. Things happen quick in your shop.  :ylsuper:
 What's the specs on the Engle 56?
Offline hemiken
Re: Cam lobe wear
« Reply #132 on: October 25, 2008 - 07:31:25 PM »
Hey BC,
wouldn't your pistons be -5cc with the valve relief and not +5 like you have above.
If it is -5, i did the calculator with compressed Felpros at .038 and came up with 10.87 compression.
Re: Cam lobe wear
« Reply #133 on: October 25, 2008 - 08:15:47 PM »
According to spec it should be +5, you add combustionchambers volume by the reliefs. Domepistons is minus.
Re: Cam lobe wear
« Reply #134 on: October 26, 2008 - 06:36:52 AM »
The K56 has 504/504 lift, 272 running duration, 224 @ .050, 110 lobe centers and 336/336 gross cam lift.
Should give good torque, idle and vacuum. Now I don't know if the compression will be too high.
My options are to restore a pair of untouched -906 I have or a pair of 440source heads I had planned to use for the Chally
but that's only for later.  :clueless:
