Author Topic: Cam lobe wear  (Read 31713 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Re: Cam lobe wear
« Reply #150 on: October 27, 2008 - 03:06:03 AM »
The 1039 is 0,010 thicker and has a bigger bore (116,586) which adds volume to get my comp down.
Question, why isn't there any gasket included for the oilpump in the big set from felpro?
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Re: Cam lobe wear
« Reply #151 on: October 27, 2008 - 10:22:49 AM »
I have always had an oil pump gasket in the set ,, usually in one of the smaller group packs
Re: Cam lobe wear
« Reply #152 on: October 27, 2008 - 12:19:20 PM »
I only have the o-rings in my sets  :(
Re: Cam lobe wear
« Reply #153 on: October 31, 2008 - 01:09:07 PM »
Got the headgaskets today so I can continue during the weekend. Now it's also time to determine TDC while the intake is off.
Camlobes cyl 1 is all in "rest", both valves closed, camlobes cyl 6: exhaust valve closing and intakevalve will start to open.
Rotor should now point at sparkplugcable cyl 1?
Offline LAA66
Re: Cam lobe wear
« Reply #154 on: October 31, 2008 - 11:23:18 PM »
 On a small block drop in the oil pump timing gear a little early and let it fit down so the slot faces #1 as you found TDC #1. Tehn the distributor will point out as desired. It could be a tooth off but you will know by the crank rotation to valve action.
Re: Cam lobe wear
« Reply #155 on: November 01, 2008 - 03:25:47 AM »
yes the engine should now be firing #1 cyl so the rotor is point where you want #1 to be on the cap , actually if you rotate the engine back about 20* & line up the reluctor & pick up the timing will be set & it will fire right up
Re: Cam lobe wear
« Reply #156 on: November 01, 2008 - 03:35:00 AM »
 :2thumbs: Could I also have seen on the movements of the pistons which one beeing at TDC?
Re: Cam lobe wear
« Reply #157 on: November 01, 2008 - 04:16:33 AM »
yes & no , both 1&6 should be at TDC at the saem time so only the cam determines which one is firing
Re: Cam lobe wear
« Reply #158 on: November 01, 2008 - 02:24:23 PM »
Finally got the Hemi headgaskets so I could continue, pain in the a** to paint when only the block has been machinewashed.
Engine turns around fine so I hope it will be a pleasent start up.
Offline hemiken
Re: Cam lobe wear
« Reply #159 on: November 01, 2008 - 05:17:32 PM »
Hey BC, you know it is a good sign when it is all buttoned up with color on it buddy :2thumbs:  getting a whole lot closer now :woo:
Re: Cam lobe wear
« Reply #160 on: November 01, 2008 - 05:31:29 PM »
 :cheers: friend. As much as I look forward to startup as scared I am something will go wrong I guess.  :clueless:
Offline hemiken
Re: Cam lobe wear
« Reply #161 on: November 01, 2008 - 05:34:35 PM »
Ancxios times my friend, hope everything runs smoothly :2thumbs: except the cam idle :smilielol: rumpity rumpity rump :woo:
Offline LAA66
Re: Cam lobe wear
« Reply #162 on: November 01, 2008 - 09:52:12 PM »
 Looks like you are doing everything right (except the orange painted balancer). :lol: Don't worry it will come together this time. :thumbsup:
Re: Cam lobe wear
« Reply #163 on: November 04, 2008 - 01:41:26 PM »
Ready for installation but I think I will keep it on the stand, nothing can go wrong then.  :thinkerg:
Re: Cam lobe wear
« Reply #164 on: November 04, 2008 - 02:08:11 PM »
it will be tough to drive on a stand !!! :roflsmiley:
