Cam lobe wear
Author Topic: Cam lobe wear  (Read 31707 times)
Offline wally426ci
    • maryland mopars
Re: Cam lobe wear
« Reply #165 on: November 04, 2008 - 05:04:39 PM »
I assumed the balancers were supposed to be engine color. every one Ive ever taken apart was....  :dunno: lookin good!  :2thumbs:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline LAA66
Re: Cam lobe wear
« Reply #166 on: November 04, 2008 - 10:16:03 PM »
 Just kidding really, youre probably right Wally426 that's the correct color dampner in the pictures. :cheers: I painted mine black for looks and added the white TDC line for contrast. The timing tape takes care of the that item though.
 So when are you going to drop her in the bay BC?  How about a Youtube/live initial firing for us guys?? :stirpot:
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Re: Cam lobe wear
« Reply #167 on: November 05, 2008 - 10:32:44 AM »
Will drop it in when my diareé from beeing scared of a rod flying out of the block is gone.  :roflsmiley:
If somebody teach me making a video and put it on yuotube I will do it, have a cellphone with camera and a digital videorecorder.  :2thumbs:
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Re: Cam lobe wear
« Reply #168 on: November 06, 2008 - 02:09:48 PM »
Had a big problem alone getting it in, the tranny was still there and gave me problems. Had to remove the enginemounts.  :pullinghair:
Offline LAA66
Re: Cam lobe wear
« Reply #169 on: November 06, 2008 - 08:49:41 PM »
 What a pain in the arse. Sometimes it's easier to load it with the trans on. Just need to raise the front end enough to get the tail shaft to clear the ground. Movin along tho bro. :cheers:
Re: Cam lobe wear
« Reply #170 on: November 06, 2008 - 09:29:56 PM »
the easiest way by far is to slide the engine in from the bottom fully assembled
Re: Cam lobe wear
« Reply #171 on: November 09, 2008 - 02:37:58 PM »
Finished the underside today. Except some problems getting the exhaustpipe to manifold correct on the driverside due to my big hands
it went good. Found again some loose bolts from the previous restorer.
My daughter will put the startup on youtube so watch out.  :bigsmile:
Offline 422STROKER
  • Member Since 6/3/06
Re: Cam lobe wear
« Reply #172 on: November 09, 2008 - 02:58:59 PM »
 :popcorn:
Glad you are moving along!
Tom :2thumbs:
Tom
Re: Cam lobe wear
« Reply #173 on: November 11, 2008 - 07:27:26 AM »
Please help me, when I turn the key I have a metallic squesse/noice I never had by turning it manually, I've tried 50 times
with the wrench without problems. :swear:
Offline hemiken
Re: Cam lobe wear
« Reply #174 on: November 11, 2008 - 07:31:35 AM »
Is the starter meshed properly ?  Bolted up tight
Offline wally426ci
    • maryland mopars
Re: Cam lobe wear
« Reply #175 on: November 11, 2008 - 07:36:48 AM »
It could be the starters natural noise..... My junkyard find Mini-starter sounds fine. But, my fathers "autopart store" mini-starter sounds like someone is digging into precious metal with a screwdriver...  :dunno:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline hemiken
Re: Cam lobe wear
« Reply #176 on: November 11, 2008 - 07:57:18 AM »
Maybe take the starter off and do a bench test, and check for noises that way :dunno:
Re: Cam lobe wear
« Reply #177 on: November 11, 2008 - 07:58:41 AM »
Could it be that I took the converter from the charger and the wearpattern is different?
Offline tactransman
Re: Cam lobe wear
« Reply #178 on: November 11, 2008 - 10:38:19 AM »
I have never had that be an issue.  :grinno:
Terry-tactransman
Union, Mo.
Offline tactransman
Re: Cam lobe wear
« Reply #179 on: November 11, 2008 - 10:39:01 AM »
It isn't the dust cover rubbing,is it?
Terry-tactransman
Union, Mo.
