Author Topic: Cam lobe wear  (Read 31699 times)
Offline 71chally416
    • The Streetwalker
Re: Cam lobe wear
« Reply #180 on: November 11, 2008 - 12:13:35 PM »
Loosen and reposition it slightly.
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Re: Cam lobe wear
« Reply #181 on: November 11, 2008 - 03:06:01 PM »
The starter?
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline 71chally416
    • The Streetwalker
Re: Cam lobe wear
« Reply #182 on: November 11, 2008 - 03:39:18 PM »
Yes.  :2thumbs:
Re: Cam lobe wear
« Reply #183 on: November 11, 2008 - 03:53:19 PM »
Will do!  :cheers: First have to go to Sweden for a week for my work. Keep you updated when I'm back.
Offline 71chally416
    • The Streetwalker
Re: Cam lobe wear
« Reply #184 on: November 11, 2008 - 04:35:15 PM »
When I changed trannies my mini-starter made a hell of a noise. We had it on the lift, so we just lossened it up and jiggled it around and retightened it and the noise went away.
Re: Cam lobe wear
« Reply #185 on: November 12, 2008 - 01:42:37 AM »
What also came to mind is that the converter I now use have 7/16" bolts while the other one had 5/16" so the cover is maybe also an issue.
Offline 71chally416
    • The Streetwalker
Re: Cam lobe wear
« Reply #186 on: November 12, 2008 - 02:05:32 AM »
Possibly, if you have the wrong bolts. They should have thin heads.
Re: Cam lobe wear
« Reply #187 on: November 12, 2008 - 02:29:41 AM »
on a smaller converter the bolts can hit the cover
Offline hemiken
Re: Cam lobe wear
« Reply #188 on: November 12, 2008 - 04:00:10 AM »
:iagree: because you have been cranking it you may very well see a wear mark on the heads now, have a good look at the area. :2thumbs:
Re: Cam lobe wear
« Reply #189 on: November 17, 2008 - 05:59:43 AM »
Wasn't that difficult to discover the problem once the cover was off.  ;) Now it's ready for start up.
Offline willard
    • 1970 Challenger R/T
Re: Cam lobe wear
« Reply #190 on: November 17, 2008 - 07:17:10 AM »
I have the same problem - bolts hit the cover so I have it removed till the tranny gets a new hi-stall tc.
1970 383 R/T SE
Offline LAA66
Re: Cam lobe wear
« Reply #191 on: November 17, 2008 - 10:03:25 AM »
  :cheers:   :bigshades: :popcorn:
Re: Cam lobe wear
« Reply #192 on: November 17, 2008 - 02:13:50 PM »
First startup went good, 20 minutes of good oilpressure and temp. The second, one hours later you see at youtube: GTX oilleak by Moparsweed.
See the spray of oil and in a few seconds almost all oil was on the floor, I hope the noice is from the belts getting some oil sprayed on them.
I don't know if the pumpgasket blew or what it is, I just want to give up for the moment. If the bearings ....................... :'( :'(
« Last Edit: November 17, 2008 - 02:35:04 PM by Belgium Cuda »
Offline 71chally416
    • The Streetwalker
Re: Cam lobe wear
« Reply #193 on: November 17, 2008 - 05:54:02 PM »
The only luck you seem to have is bad luck  :bricks1:
Offline 422STROKER
  • Member Since 6/3/06
Re: Cam lobe wear
« Reply #194 on: November 17, 2008 - 06:08:00 PM »
Man that spray was strong.  Was it the oil pump?
Tom :popcorn:
Tom
