Author Topic: Cam lobe wear  (Read 31686 times)
Offline 422STROKER
  • Member Since 6/3/06
Re: Cam lobe wear
« Reply #255 on: January 29, 2009 - 05:35:13 PM »
Where are you getting your 12V for the choke?  Sounds like if it isn't staying open it doesn't have 12v.
Tom
Tom
Offline Aussie Challenger
Re: Cam lobe wear
« Reply #256 on: January 29, 2009 - 05:55:29 PM »
  I would disconnect the choke & wire it open, car should start, see if this makes a difference, you won't be able to drive it though but at least you should know if it is the choke. You can adjust the choke so it doesn't close off completely, don't pump the acelerator when cranking.   :2cents:
Offline wally426ci
    • maryland mopars
Re: Cam lobe wear
« Reply #257 on: January 29, 2009 - 06:17:18 PM »
Oh no. not another electric choke gone bad....  :misbehaving:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Cam lobe wear
« Reply #258 on: January 29, 2009 - 06:54:03 PM »
Do you have an electric choke? It SHOULD stay open once warmed. Be careful in temps below 40* F. It is easy to flood the car while trying to start it. Give the pedal one pump and turn the key...unless the car has sat for a few weeks, then it may take another pump or two.
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Re: Cam lobe wear
« Reply #259 on: January 29, 2009 - 07:19:31 PM »
Thanks guys :2thumbs: I will check proper choke setting tomorrow. Maybe the ground is bad, it's only on the carb itself. The positive
comes from the wipermotor.What about the vacuumadvance, do you have it connected or plugged?
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline 422STROKER
Re: Cam lobe wear
« Reply #260 on: January 29, 2009 - 07:46:16 PM »
You need to find a good clean 12V power source for the Choke.  The ground may need to be relocated depending on where those carb studs go.  Do they go into the spacer and another set into the manifold or do they go all the way through?
Street motor would only benefit from the vacuum advance.  i run it on mine.
Tom
Tom
Re: Cam lobe wear
« Reply #261 on: January 29, 2009 - 07:53:50 PM »
  looking at the picture the earth/ground is good but I would be looking for an ignition (12v) switched positive source, the wiper might not be that good.   :cheers:
Re: Cam lobe wear
« Reply #262 on: January 29, 2009 - 08:45:45 PM »
the choke should open in under a minute if you have a 12v source feed to it , the blue wire at the ballast will be 12v , as soon as the engine fires vacuum should pull the choke open apprx 1/3 this could be where the problem is in that the choke is not pulling open enough with vacuum
Offline wally426ci
    • maryland mopars
Re: Cam lobe wear
« Reply #263 on: January 29, 2009 - 10:22:59 PM »
I stopped fiddling with the wiring and ran mine straight into the accessory tab on the fuse block. I used a piggy back connector.  :nono: I know.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Cam lobe wear
« Reply #264 on: January 30, 2009 - 02:40:50 AM »
Wally
it should have some kind of fuse inline just incase to prevent a fire other than that no issue
Re: Cam lobe wear
« Reply #265 on: January 30, 2009 - 09:44:21 AM »
Problem is/was bad connection of chokewires. the positive goes in to the bulkhead for the wiper but only "sticked in.
Chryco, Which blue wire on the ballast were you refering to that I could use?
« Last Edit: January 30, 2009 - 11:48:05 AM by Belgium Cuda »
Offline wally426ci
    • maryland mopars
Re: Cam lobe wear
« Reply #266 on: January 30, 2009 - 10:09:41 AM »
Wally
I'll stick a link in there..  :2thumbs:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Cam lobe wear
« Reply #267 on: January 30, 2009 - 01:30:30 PM »
the one towards the passenger side of the car , it is dark blue & feeds the ignition ECU also
