Author Topic: Steering seals  (Read 1886 times)
Offline mrbill426
    • All Around Mopars
Steering seals
« on: August 08, 2008 - 11:59:59 PM »
I'm wondering, is there a good source for the original type seal (boot) that fits between the pitman arm and the center link on the Ebodies?  Same question for the tie rod ends and the idler arm sponge washers; I don't need hardware, just the seals.
Thanks
 :working:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Re: Steering seals
« Reply #1 on: August 09, 2008 - 02:41:50 AM »
the pitamn arm just used a foam seal , the tierod boots are available in Poly from Energy suspension or in ther HElp line in rubber
Re: Steering seals
« Reply #2 on: August 09, 2008 - 04:56:45 AM »
OE style avail....a bit pricey, Energy suspension works but looks nothing like stock
http://www.monicattichrysler.com/comersus/store/comersus_viewItem.asp?idProduct=1440
Offline mrbill426
    • All Around Mopars
Re: Steering seals
« Reply #3 on: August 09, 2008 - 08:58:53 AM »
My idler arm has (torn) foam seals at top and bottom, the tie rods have cone shaped boots, but the existing pitman arm "boot" is much shorter and looks more like a bellows.
bullitt99, those look about right but wholly cr*p, are they kidding!  :22yikes: $208.00  ??
MOPAR or NO car!
Re: Steering seals
« Reply #4 on: August 09, 2008 - 11:12:59 AM »
That's a Mopar Part, I searched the part# & that's as low as they go for....some ask 230+.
Someone stated here once that you can track down the individual pieces through Mopar & save a few bucks......or spend about 50 on the ill fitting Energy Suspension pieces...what I did.
Re: Steering seals
« Reply #5 on: August 09, 2008 - 11:43:46 AM »
The top left & bottom right sure do look familiar
http://www.ytmag.com/cgi-bin/store/search_parts.cgi
Offline mrbill426
    • All Around Mopars
Re: Steering seals
« Reply #7 on: August 09, 2008 - 07:10:36 PM »
Yes, those two resemble what is on my pitman arm now; very low proflle bellows with a "lip" to fit in the groove around the arm.
MOPAR or NO car!
Offline mrbill426
    • All Around Mopars
« Last Edit: August 09, 2008 - 07:19:09 PM by mrbill426 »
MOPAR or NO car!
Offline mrbill426
    • All Around Mopars
Re: Steering seals
« Reply #9 on: August 09, 2008 - 07:20:17 PM »
That one looks more like a tie rod boot than a pitman arm boot.  Maybe a generic photo?
MOPAR or NO car!
Re: Steering seals
« Reply #10 on: August 09, 2008 - 07:53:58 PM »
Maybe...mine was kind of flat compared to the tie rod boots.
