I have some annoying noise from the front suspension¨¨"creek"
Author Topic: I have some annoying noise from the front suspension¨¨"creek"  (Read 1003 times)
Offline cudaman-440
  • Go-manGo
« on: August 09, 2008 - 06:07:09 AM »
I have some annoying noise from the front suspension¨¨"creek"  :violin:
Is it someone ho has some tip?? :working:
Re: I have some annoying noise from the front suspension¨¨"creek"
« Reply #1 on: August 09, 2008 - 06:26:40 AM »
My car had sat for roughly 20 years & had creeks that pretty much went away when I greased the ball joints & tie rod ends.    Have you done any work on the front suspension yet?
Welcome to CC.Com cudaman  :wave:
Offline cudaman-440
  • Go-manGo
« Reply #2 on: August 09, 2008 - 06:35:09 AM »
I have greased the front suspension
« Reply #3 on: August 09, 2008 - 06:40:43 AM »
Have you replaced the upper & lower controll arm bushings?...Shocks?
Offline cudaman-440
  • Go-manGo
« Reply #4 on: August 09, 2008 - 06:56:10 AM »
I haven`t replaced any parts in the front suspension-yet...
« Reply #5 on: August 09, 2008 - 12:09:07 PM »
If your not ready to do a suspension rebuild best thing would be to soak each pivot point with penetrating spray lubricant.... do one at a time & see if you can tell any change & you will know what parts to target.
Offline BB73Challenger
« Reply #6 on: August 10, 2008 - 04:26:05 PM »
My passenger side strut rod began to creek, really loud!
After inspecting to make sure nothing was wore, loose or damaged, I lubed all points as said above and that took care of it.
Jeff from Cleveland, Ohio
