Author Topic: what year mustang wheels  (Read 1160 times)
Offline 70ptta
« on: August 10, 2008 - 12:11:33 AM »
I did a search and I didnt find what I was looking for.  I need some cheap wheels to roll my cuda around so I figured mustang wheels would be it.  What years will bolt on our e bodies with out spacers?  Thanks
Offline duodec
Re: what year mustang wheels
« Reply #1 on: August 10, 2008 - 01:41:13 AM »
What I remember reading is that most ford 5-lug passcar wheels from the mid '60s into the '80s will bolt on; they use the same bolt pattern.  However the center hole is a little larger, so the wheel won't index tightly on the hub center like stock Mopar wheels.
I have 1968 Mercury Cougar mag wheels on my '71 Challenger; they worked fine.
I understand that most 1970-80s Jeep 5-lug wheels will also fit.  Since you are just using them for rolling around, the hub size difference shouldn't matter.
« Reply #2 on: August 10, 2008 - 02:02:47 AM »
Check your local http://www.craigslist.org/about/sites.html
should be able to find something like this eventualy
http://nashville.craigslist.org/pts/774678197.html
Offline Aussie Challenger
« Reply #3 on: August 10, 2008 - 03:55:23 AM »
  Why not just get a cheap set of junk-yard wheels off a '70 up MOPAR, so long as the tyre holds air it will work.   :bigsmile:
Offline 70ptta
« Reply #4 on: August 10, 2008 - 05:28:23 PM »
i wanted to roll around in them for a little after so i can have some decent wheels while i save up for the good ones.
Offline Morris'_Mopars
« Reply #5 on: August 16, 2008 - 08:32:48 AM »
Jeep Liberty and the LX cars are the same bolt pattern also. :2cents:
Morris' Mopars LLC
Raymond, Illinois
Mopar performance at affordable prices.
