Author Topic: Home Brew Rust remover  (Read 5363 times)
« on: August 10, 2008 - 02:45:06 PM »
Over a year ago, I posted here about how Molasses and water mixed together removing rust. Way cheaper than buying Evapo Rust or Rust away by the gallons. They cost 21-30 each.
I never got around to trying it out till today. I had an Accel high torque starter I took apart to see if I could get it back to life.
So far after just a few hours, I can see results happening.
Here's an article that I found that had me decide on trying it out.
http://www.wr6wr.com/newSite/articles/columns/wp0906/wp0906.html
Offline NoMope Greg
Re: Home Brew Rust remover
« Reply #1 on: August 10, 2008 - 03:26:09 PM »
 :popcorn:
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #2 on: August 10, 2008 - 04:22:02 PM »
Interesting article   :popcorn:
Offline plumcrazy704406
« Reply #3 on: August 10, 2008 - 05:43:21 PM »
 :wow: thx for the post. neat article.
I wonder if it will work on me? :roflsmiley:
This thought may not be politically correct, but is an opinion offered. It may be correct? or it may be wrong? It is not designed to appease those needing shelter from the real world.
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #4 on: August 10, 2008 - 05:56:43 PM »
How bad is the sticky mess after the rust is gone?  :dunno:
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
« Reply #5 on: August 10, 2008 - 07:05:47 PM »
It's diluted with warm water. More like a watered down syrup. Washes off real easy.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #6 on: August 10, 2008 - 07:55:31 PM »
Tom
Offline 71chally416
    • The Streetwalker
« Reply #7 on: August 12, 2008 - 12:57:06 AM »
Now I just need about 50lbs of that powder and a tank big enough to put my car in  ;D
« Reply #8 on: August 12, 2008 - 01:14:47 AM »
I pulled the starter out today washed and wire brushed it. Perhaps a little stronger mix would've improved it.
Looks like its re usable. pics later.
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #9 on: August 12, 2008 - 01:20:36 AM »
Thanks for the link, Topcat.  I'm going to print that receipe out and give it a try.  How's the lead work coming along?
Some more info here.
http://www.massmopar.com/yabb/YaBB.pl?num=1135525788
Tom :2thumbs:
Another cool link...thank you, Tom.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
« Reply #10 on: August 12, 2008 - 01:45:26 AM »
All 6 areas are leaded up now. I did 5 that needed doing. Been shaving and shaping it with a file.
Offline 422STROKER
« Reply #11 on: August 12, 2008 - 10:11:24 PM »
No sweat, I remember seeing it a few years ago and thought it was pretty cool.
Let us know how you make out Topcat.
Tom
Tom
« Reply #12 on: August 12, 2008 - 11:43:32 PM »
I did the innards. Part of it is still soaking in the juice. Came out way better than it was before.
This starter is a just to keep me busy till the week end comes project.
Offline Aussie Challenger
« Reply #13 on: August 13, 2008 - 04:30:02 AM »
  I used a 44gl oil drum many years ago when I was restoring a 26 Dodge 4, most parts went OK. I left them in usually about 7 or 8 days, washed them off with warm water, then hit them with under coat for protection. Some of the more rusted parts were pitted slightly so they needed a little bit of extra rubbing to smooth out, but all the rust was eaten out.   :2thumbs:  Just as well those older cars panels were thick, at least twice as thick as todays cars.   :cooldancing:
« Reply #14 on: August 14, 2008 - 01:21:58 AM »
These will go in the drink in a day or so. For comparing before vs. after. I'll post results next week.   :popcorn:
