Author Topic: Home Brew Rust remover  (Read 5366 times)
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
Re: Home Brew Rust remover
« Reply #15 on: August 14, 2008 - 06:52:05 PM »
 :popcorn:
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline NoMope Greg
« Reply #16 on: August 14, 2008 - 07:16:55 PM »
 :popcorn:  :popcorn:  :popcorn:
I have a rusty set of headers and a large trash can...
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #17 on: August 14, 2008 - 07:26:36 PM »
I hear that you can get big sacks of powdered mollasses at the hay feed type stores.
Then use something like a big horse water trough. Dip you whole diff in there or engine block.
Offline 71bigblock
    • Steve's Mopars
« Reply #18 on: August 14, 2008 - 09:35:39 PM »
Topcat's right.  We have fed 50 lb sacks to the cows.  Not at one time of course, just a few pounds for the whole herd per day.  That would dilute pretty good I think.
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #19 on: August 15, 2008 - 01:22:04 AM »
Very interesting....hummm  :thinkerg:
« Reply #20 on: August 19, 2008 - 09:50:58 PM »
Before and after.
I did wire brush it but it only took a minute to get it like this.
Everything came right off washing and brushing at the same time.
Offline 71chally416
    • The Streetwalker
« Reply #21 on: August 19, 2008 - 10:58:06 PM »
Very impressive! Now, about this stuff also removing copper. Will that affect the amature windings and the field by taking the varnish off the wires? You might now have a dead short so I would hook the starter to a battery and bench test it if you don't want it to catch on fire in the car and burn the car up.  :bricks1:
Offline Aussie Challenger
« Reply #22 on: August 19, 2008 - 11:19:16 PM »
  Doesn't attack any painted surface and that includes the varnish on the copper wires, it is however a good idea to test in case the varnish had already started to break down.   :iagree:
Offline 71chally416
    • The Streetwalker
« Reply #23 on: August 19, 2008 - 11:34:51 PM »
I'm going to try this stuff on some heads I have that are rusted. I'll post up the results.  :thumbsup:
« Reply #24 on: August 19, 2008 - 11:53:52 PM »
Definitely post pics of the progress and your findings.  :2thumbs:
Anyone thought about doing this to a slightly rusty trunk lid? Beats blasting sheetmetal.
I bought some of those wire brush kits from harbor freight the other day when I was there shopping for some other stuff. They're 99 cents and really work good loosening up thick spots. I recommend taking it out after the second day and wire brush the heavy spots then back in again to help speed up the process. If you want to keep a natural look and don't want to paint afterwards, you can get some stuff from the company called Evapo Rust to prevent cast rust flash coming back. I had a free sample I got at SEMA and put it on the starter.
http://www.evapo-rust.co.nz/rust%20block%20dle%20email%20vs.pdf
« Last Edit: August 19, 2008 - 11:57:26 PM by Topcat »
Offline Jacksboys
« Reply #25 on: August 21, 2008 - 01:28:11 PM »
WOW that is very impressive.   :2thumbs:
« Reply #26 on: August 21, 2008 - 04:30:45 PM »
The rust block product I mentioned about would work well on keeping non painted metal parts like on suspension components from rusting if you're planning on going back to OEM stock show car. It doesn't leave a film thats visible.
