Author Topic: Was there plastic behind the back seat from the factory?  (Read 1709 times)
Offline matt63
« on: August 11, 2008 - 01:29:20 PM »
I was wondering if there was poly/plastic sealing the passenger compartment from the trunk and rear axle area of the car.  I don't remember ever seeing such thing.  Was it done?  I'm still trying to reduce the exhaust smell in the car. I was thinking of pulling the back seat and package tray and covering the area with poly -kind of like how the doors were sealed.
Matt in Edmonton
'68 Valiant
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
Re: Was there plastic behind the back seat from the factory?
« Reply #1 on: August 11, 2008 - 03:20:54 PM »
No plastic that I'm aware of, but there was a cardboard divider and insulation.  JayBee hooked me up with an AWESOME template that I'm using to make mine, then a CC member in the next town over will be getting it, maybe he can mail it to you when he's done, or I will if he won't.
See the link here:
http://www.cuda-challenger.com/cc/index.php?topic=47300.0
I have to publicly thank JayBee again, his template is AWESOME!!!  I haven't gotten around to making it yet, but I did buy the hardboard to make it.
Should only take a couple hours max to make, and the total cost will be around $5.  Sweet!!   :woohoo:
« Last Edit: August 11, 2008 - 03:24:11 PM by RabidScott »
1970 Dodge Challenger
13.9 @ 101 with stock internally 440, OD 4 speed, 3.23 LSD
WaywardGarage.com
Offline matt63
« Reply #2 on: August 11, 2008 - 03:39:00 PM »
i have the divider but no insulation. Thanks.
Matt in Edmonton
'68 Valiant
« Reply #3 on: August 11, 2008 - 05:35:12 PM »
Matt,
  Once upon a time I had the same problem. The culprit? The gaskets were shot around my tail light bezels. The exhaust was getting in that way. I replaced them and haven't had any smell since.
Offline hotrod98
    • Maniac Musclecars
« Reply #4 on: August 11, 2008 - 05:39:14 PM »
You definitely have a problem that should be repaired correctly.
The next long road trip with the windows up could be your last.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Alaskan_TA
« Reply #5 on: August 11, 2008 - 08:30:59 PM »
Original dividers did not have any insulation.
Offline matt63
« Reply #6 on: August 12, 2008 - 09:50:24 AM »
I plugged one large hole in the cowl (I have no idea what went there) and things are quite a bit better now.  I had used clear silicone on the tail light gaskets.  They actually look to be in pretty good shape.  I still smell a bit like exhaust after a trip.  It's a fair weather car so I haven't taken any drives with the windows up!  I still have to plug the drain holes in the bottom of the trunk extensions to see if that helps.  I thought that sealing the trunk from the passenger compartment might help too.
Matt in Edmonton
'68 Valiant
Offline MrMopar440
« Reply #7 on: August 12, 2008 - 10:25:12 AM »
You're not alone. I have been chasing the same thing. Waiting for an order from Roseville with new nuts to tighten down the taillights good and snug and see what happens. I think a lot of mine is tailpipe placement as well. I had them cut just shy of the bumber (under the valence not through).
« Reply #8 on: August 12, 2008 - 11:06:02 AM »
if the 1/4s have been replaced there may be leaks between the panels [inner & outer ] , tailight seals , floor plugs & trunk seals can be an issue as well
Offline matt63
« Reply #9 on: August 12, 2008 - 11:12:50 AM »
My tips don't stick out a lot either.
Matt in Edmonton
'68 Valiant
Offline matt63
« Reply #10 on: August 12, 2008 - 11:25:27 AM »
That's an interesting point as the quarters have been replaced.  The trunk does leak.  I thought it was the tail lights but sealing them didn't help.  I'll have to do a little investigation with a water hose.  Perhaps it's the new trunk seal.  Either way installing a plastic liner behind the divider should take care of the problem hopefully.  I'll plug every hole I can find!
Matt in Edmonton
'68 Valiant
Offline hotrod98
    • Maniac Musclecars
« Reply #11 on: August 12, 2008 - 07:42:54 PM »
The extensions should stick out of the rear valance about 1/2 inch. If not, the exhaust will drift up under the car and into the trunk. I've seen a lot of muffler shops mount them flush to the valance for looks.
1971 Cuda Drag Car
« Reply #12 on: August 12, 2008 - 07:47:55 PM »
You would think weather-stripping around the trunk lid would solve this problem, but maybe not?   :dunno:
