Author Topic: Fuel Guage  (Read 2847 times)
Offline VTMopar
Fuel Guage
« on: August 11, 2008 - 08:25:27 PM »
Last week, for the first time -- my fuel guage stopped working while out for a spin (everything else worked fine)...... the next day, when I started it = all was well again!  ???   Any ideas what is going on (possible ground?)    This is a '74 Rallye....
Thanks
Vermont MOPAR
VT MOPAR
Offline GoodysGotaCuda
Re: Fuel Guage
« Reply #1 on: August 11, 2008 - 08:59:02 PM »
I'd take a look first back at the tank sending unit. (drivers side, behind the r/r wheel). Make sure there is a good ground strap from the sending unit to the steel fuel line, and that the sender wire is nice and tight on the sending unit. May want to do a 'wiggle-test' on both and watch the gauge.
-Mike
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline VTMopar
Re: Fuel Guage
« Reply #2 on: August 12, 2008 - 09:17:32 PM »
Thanks     I take a peek at the sending unit this weekend.
Vermont MOPAR
v
VT MOPAR
Offline VTMopar
Re: Fuel Guage
« Reply #3 on: August 25, 2008 - 04:16:51 PM »
Goody (or anyone)  --  I finally got around to checking out the wiring at the sending unit (see pic).  Am I missing something?   This short green wire just goes up through the trunk to the wiring harness.... presumably to the dash.   This is a '74 -- and the fuel guage has worked fine for the past couple of years!
Vermont MOPAR
VT MOPAR
Offline cudaguy71
Re: Fuel Guage
« Reply #4 on: August 25, 2008 - 04:41:56 PM »
the green wire is the one that runs to your gauge.  You should have a wire that runs from the fuel line to ground, should be wire between the two metal lines that the rubber line hooks to.  I do not see it in the pic.  You might check and see if it is on the other side of the rubber line
1973 'Cuda Project
1971 'Cuda Project
1998 Dodge Ram 1500
2003 Dodge Dakota Sport
1979 Plymouth Arrow
Re: Fuel Guage
« Reply #5 on: August 25, 2008 - 06:22:17 PM »
Notice the rusted metal strap connecting my pick-up tube to the solid fuel line...
Offline VTMopar
Re: Fuel Guage
« Reply #6 on: August 25, 2008 - 07:56:21 PM »
MEK     Thanks for the photo.   Does the fact that mine has a Vapor Separator Assembly make a difference?   I don't see a ground wire/strap anywhere  -- is it possible it simply fell off?    Here's a pic......
Is this what I need?   http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=006&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=160273035144&rd=1
Thanks,
Vermont MOPAR
VT MOPAR
Offline Katfish
  • 70 Challenger
Re: Fuel Guage
« Reply #7 on: August 25, 2008 - 08:01:02 PM »
That's the factory part.  If you don't mind originality you can just add a small metal hose clamp to each side, and use a piece of wire to connect the 2.  This will actually provide a better ground than the clip on part.
And it will only cost $1
Re: Fuel Guage
« Reply #8 on: August 25, 2008 - 09:58:00 PM »
Definitely scrape/sand off that coating or paint that is on the sender before installing the strap for a good connection
1976 Dodge Warlock
Re: Fuel Guage
« Reply #9 on: August 26, 2008 - 01:09:59 AM »
fuel wire is blue not green BTW
Offline VTMopar
Re: Fuel Guage
« Reply #10 on: August 27, 2008 - 10:11:36 PM »
Katfish:    good idea -- will try the wire/clamp and will scrape/sand off the paint first.   Hopefully, this solves the problem.   Still very curious as to how/why it worked for well over a year since restored the gas tank.....
Thanks to all for advice; will let you know if I get it to work.
Vermont MOPAR
VT MOPAR
Offline VTMopar
Re: Fuel Guage
« Reply #11 on: September 05, 2008 - 09:56:16 PM »
 :bigsmile:
Added the missing ground wire -- and now I know when to stop -- take out a small mortgage -- and fill her up again!
Thanks to all for the help   :thumbsup:
Vermont MOPAR
VT MOPAR
