Author Topic: 295/50/15 on 8" rallye wheels?  (Read 10306 times)
Offline bb71challenger
« on: August 12, 2008 - 11:06:37 PM »
I got the idea for this thread from the other one asking about 10" rallye wheels. I pretty much know that without relocating the springs it would be impossible to make them look good with trim rings. I was wondering if anyone has stuck the really wide 295 meats on an 8" wheel? I know it would be hard but if it could be done it would actually pull the tire in a bit more for clearance. I am close to buying a set of 15" rallyes and would love to put some 2925/50/15's on my car without clearance issues. Anyone have any experience in this area?
*Brett*
Offline 500Stroker
Re: 295/50/15 on 8" rallye wheels?
« Reply #1 on: August 13, 2008 - 12:28:12 AM »
Here you go.  Exactly what you asked for.  The only mod I did was use the offset rear spring hangers.  The front are not offset.
« Last Edit: August 13, 2008 - 12:30:24 AM by 500Stroker »
Offline 500Stroker
« Reply #2 on: August 13, 2008 - 12:41:00 AM »
A couple more............  Keep in mind they are only 26" tall.  My car drives 5mph slower at the same RPM as with 28" 275/60-15
Offline Carlwalski
« Reply #3 on: August 13, 2008 - 01:17:57 AM »
I'm pretty sure it can be done, BFG's site says a 295 is suitable for 8-10" rims. I wouldn't get too comfortable with 295s, they stopped producing them but are going to remake them again. But, they may stop again as well. The market isn't too big for them. 275/60s are the gold for BFG T/A Radials. So setting a car up solely for 295s is risky. I'm pretty sure 295s on an 8" rim will also increase the sidewall bulge dramatically. A 10" rim will keep it more "square" if you will. An 8" rim will bulge them out and have less tyre in contact with the ground due to pinch. I honestly don't see 295s as an improvement and would back 275s them outperforming 295/50s on the 1/4 (not track though). Mods for very little and in real world driving you won't notice any difference + the lower OD. Each to his her own though.
0.02C
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 360 'CUDA
« Reply #4 on: August 13, 2008 - 01:46:53 AM »
My friend has the 8" Pontiac snowflakes with 295s on them.  They do have a bigger sidewall bulge then my 10" Centerlines with 295s.
His GTO looks great from the rear though even if some of the meat is wasted
« Last Edit: August 13, 2008 - 01:50:46 AM by 360cuda »
Offline SalTy71CuDa
  • Death Comes In Form Of A Pie!
« Reply #5 on: August 13, 2008 - 07:30:40 PM »
   Actually you could fit them on 7" rims. I had a set of Cragger SST's that were 15x7 I had no problem running either my L60-15 Mickey Thompson Indy Profile S/S's OR my BFG 295/50/15.
~Wes
heres a pic of my old Micky's
« Last Edit: August 13, 2008 - 07:42:21 PM by SalTy71CuDa »
Offline Carlwalski
« Reply #6 on: August 13, 2008 - 07:34:06 PM »
Being able to fit them and being safe are two different stories. ;)
I can fit size 20 shoes, but I can't run in them. :grinno: Be safe, following tire manufactureres recommendations.
Offline SalTy71CuDa
« Reply #7 on: August 13, 2008 - 08:02:32 PM »
Actually I kinda was  :screwy: L60-15's your able to use a 7-10" rim atleast from what I read though Jeg's and Summit. The 295's .... well ok you got me there lol. But honestly the only difference I've ever noticed was the height of the tire... oh and that the 50's rode like garbage. Just my opinion. ;D
So ok to be safe go with a 8"  :bigsmile:
« Reply #8 on: August 13, 2008 - 11:26:57 PM »
1st pic; 295/65 on and 8" rim.
2nd pic 295/50 on 8" rim.
Offline Carlwalski
« Reply #9 on: August 14, 2008 - 12:23:01 AM »
I re-sized your avatar HP2 so no one will have to use the scroll bar regardless of their screen size. I have never been able to see yours, I have a 17" screen too, don't have to, just did one because all I have ever seen properly is the rear end and a shed lol. Cheers. PS: Never seen or heard of 65 series tyres until now.
« Last Edit: August 14, 2008 - 12:25:08 AM by Carlwalski »
« Reply #10 on: August 14, 2008 - 10:23:56 PM »
Thanks Carl!  :ylsuper:
295/65 is a BFG drag radial. They are around 30 inches tall, about 29 when on the car. 12 inches wide section width on an 8 inch rim.
« Reply #11 on: August 14, 2008 - 11:35:21 PM »
I always have and still do like the lower profile of the 295/50/15. It even gives a bit more clearance. Hell, I have 2.94 sure grip so with a 26" tire it will be kinda like I have my 3.23's back in there  :bigsmile: Thanks everyone for posting pics of your setups.  :2thumbs:
*Brett*
