Author Topic: Replicating e-body trunk seam sealer  (Read 2467 times)
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
« on: August 13, 2008 - 12:21:24 AM »
Has anyone tried to replicate the type of seam sealer used in the trunk and floor pans of e-body (and I'm sure other Mopes)? It would appear they had some sort of gun-applicator and weren't to picky! Thanks - and SORRY for the crappy pic, I just cropped it from something else...
Offline alphabuck
    • Pics of my project
Re: Replicating e-body trunk seam sealer
« Reply #1 on: August 13, 2008 - 08:43:42 AM »
almost identical stuff even leaves the brush marks behind
Offline heminut
« Reply #2 on: August 14, 2008 - 11:44:25 AM »
 :iagree: That's what I used on mine and it looks pretty good.
1970 5.7 Hemi Cuda
Offline e-tek
    • E-Tek Resto's
« Reply #3 on: August 14, 2008 - 12:05:34 PM »
That is what I've geneally used and what I bought for this project.  But- it is the specific texture I was more or less referring to. As you can see, it's not "brush-marked", but more like it was deposited by a low-pressure air device - as can be seen in the sealer at the very bottom of picture. I was on the Autobodystore.com site and a GREAT suggestion is made there: to use a Turkisk towel (basically a heavy terry-cloth), first dabbed in grease or something to avoid sticking, and to press it out to get that same "textured" look.
Here's the link - scroll to bottom: http://autobodystore.com/seamsealer.shtml
I'll be trying it this weekend and I'll post my results!
Offline FJ5_440
  • Wisconsin
Does anybody have a good photo of the factory trunk seams they could post for e-tek?  I can't really see what you are trying to replicate from that first picture, but I don't think the factory stuff was as textured as you indicated. :clueless:
** Shane **
Offline cudaguy71
« Reply #5 on: August 14, 2008 - 03:35:01 PM »
That's a crop from one of my pictures, but yes that is what the factory seam looks like on my 73 cuda.
« Last Edit: August 14, 2008 - 03:37:52 PM by cudaguy71 »
1973 'Cuda Project
1971 'Cuda Project
1998 Dodge Ram 1500
2003 Dodge Dakota Sport
1979 Plymouth Arrow
Offline wally426ci
    • maryland mopars
« Reply #6 on: August 14, 2008 - 05:13:38 PM »
from the trunk floor to the trunk extension seems..... I just used regular caulk, but it would be cool to replicate it.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline stinger
« Reply #7 on: August 16, 2008 - 12:26:38 AM »
I would'nt use grease.try some acry-sol or a prep-sol of some sort.
Offline snowdog
  • Thor-Our Belgian Tervuren-Member since 2006
« Reply #8 on: August 16, 2008 - 08:40:53 PM »
Well if you guys don't mind listening to another old Dodge Main story,  I think I can tell you how the chalking was applied.  If I remember correctly it was applied with a low psi chaulking gun and then it was brushed it in.  I did this for a day or two.  This was how the it was done for the Aspens and Volares.  Maybe Barry (Alaskan TA) has an engineering sheet on that.  But anyways the photo that 71cudaguy or e-tek is of just the chaulking gun application and the guy with the brush missed it or was on break or ????.
See ya, Snowdoggie
Scott (aka: snowdoggie) 1970 Challenger - 440 Modified - 4 Spd - White on Black - 1970 Cuda - 383 Magnum - 4 Spd - Drk. Green on Black - Howell, MI
See my "I'm gonna fix'm up someday" story at Cars in Barns.  **Dodge Main 76-78**
http://www.carsinbarns.com/Mopars%20In%20Barns/pg113mopar.htm
Offline stinger
« Reply #9 on: August 17, 2008 - 07:13:00 PM »
my original caulk in my 70 is about 2" wide and looks like it was applied with a gun and then went over with a brush with some pressure and in one direction.
Offline cudaguy71
« Reply #10 on: August 18, 2008 - 12:42:05 PM »
Here is the full seam just FYI...
1973 'Cuda Project
1971 'Cuda Project
1998 Dodge Ram 1500
1979 Plymouth Arrow
Offline stinger
« Reply #11 on: August 18, 2008 - 07:36:53 PM »
this is a shot from an original 70 chally I took at the NATS.kinda hard to see but if you enlarge it you can see it's different.I think it depends on the year,what year is your's?
