Author Topic: How do I wire two rear aftermarket speakers to my 70 e body radio???  (Read 2521 times)
Offline purplehrtchallenger
hey guys,
ok, i admit i am more of an engine guy than an audio guy, but am really pulling my hair out on this one. :pullinghair:
here is what i got:
I have a 70 e-body with a thumbwheel am-fm radio...
I have the 'rear speaker' knob on the dash...
I have the one stock speaker in the front dash...
I have two aftermarket 6x9 speakers in my rear package tray..their wires obviously do not match the wires or color codes of the rear speaker knob or radio. :banghead:
I have a mess! :bricks1:
help me out please...how am i supposed to wire this up?  my first thought was to splice the two rear speakers together, but an 'audio expert' told me not to...
any help would be most appreciated!! :worshippy
thanks,
PHC
Offline Slotts
Re: How do I wire two rear aftermarket speakers to my 70 e body radio???
« Reply #1 on: August 13, 2008 - 03:31:54 PM »
Hey PHC,
I will check my buddy's 70 service manual tonight and let you know.
I looked for your car at the Nats but didn't find it.
Slotts
« Reply #2 on: August 13, 2008 - 05:26:24 PM »
Hey Slotts!
Thanks a million...you are saving my bacon again!!   :worshippy
Had a bad experience with the engine on my 70 ebody on Thursday   :22yikes:  bottom line was I couldn't make it out to the Mecca of Mopars  :crying:
Guess i am going to have to wait until 2010 for the next Mopar Nats--got my orders to go play in the sandbox called iraq for a year come October...totally bummed  :villagers:
Offline Slotts
« Reply #3 on: August 13, 2008 - 06:31:31 PM »
Hey PHC,
I have a 11 x 17 copy of what you need. I'll send it to you. I still have your address.
If you need a trace done before you receive this, let me known.
Slotts
« Reply #4 on: August 13, 2008 - 08:13:44 PM »
To the point of using two rear speakers & how to wire them you have to be concerned with Ohms/resistance as it relates to load on the amplifier.. Chrysler used 1 8-Ohm speaker per channel, if your lucky your aftermarket speakers are 4-Ohms making this simple, you will be able to wire them in series & have 8-Ohms resistance, but if they are 8-Ohm speakers you would be better off wiring them in parallel for a total resistance of 4-Ohms. Both are shown here.
http://www.crutchfield.com/S-DSGvqbk41C8/tech/kb334.html
If this were my car I would look into one of these as your OE radio probably does not put out but a couple of watts & those new aftermarket 6x9"s are not going to sound very good underpowered. This would give you the option of left/right-front/back balance & fade and quite a bit more bang for a very few bucks + its small enough to hide.
http://www.electronicsoutfitter.com/ava-1404/boss-audio/p71824.html
« Reply #5 on: August 16, 2008 - 04:09:43 AM »
or use a small Amp
Offline 73james
  • horsepower and torque are only the beginning
« Reply #6 on: August 29, 2008 - 01:50:41 PM »
If it were mine I would buy a small 4 channel amp and wire the two rears to it and use another channel for the front speaker and you will still have another channel to play with. I would recommend a jensen 4 channel they are cheap but good.
James
