Author Topic: 143 vs 130 tooth flywheel  (Read 3411 times)
Offline 72bluNblu
« on: August 13, 2008 - 03:07:32 PM »
Ok, so like everyone else I'm converting my 904 to a 833 OD 4 speed.  :burnout:
This is part of the project when I install a rebuilt 360 to replace my 318. I have a bellhousing, numbers on it are 3743859, as well as 05305 1. I also bought a external balance flywheel for the 360, but after seeing a 130 tooth flywheel mine has to be a 143. The number on it is 5300 6741 K 68178 NH. (whew!)
So, can anyone tell me if any of this stuff will work together? Or do I have a bell for a 130 tooth flywheel and a 143 tooth flywheel to go in it? ::)
sleepychallenger
Re: 143 vs 130 tooth flywheel
« Reply #1 on: August 13, 2008 - 03:16:32 PM »
just tagging in so i can get the info too. some of it is explained in my A-833 thread in the tranny section. but im still a bit confused.
Offline asm74
« Reply #2 on: August 13, 2008 - 04:20:42 PM »
 :popcorn:
73 Challenger
Offline Changin Gears
« Reply #3 on: August 13, 2008 - 05:00:23 PM »
The  143 tooth 360 setups were for the trucks with an 11" clutch and a bellhousing that doesn't take the 833.  I don't believe there was a small block bellhousing that was for a 143 tooth/833 combo.  You need to get a 360 130 tooth flywheel.  These are much harder to find than the 143 tooth truck version.
Offline 72bluNblu
« Reply #4 on: August 13, 2008 - 06:30:14 PM »
So the 143 and appropriate bell was for the granny-low type transmissions? I know there were 360 trucks that came with 833's, they must have had 130 tooth flywheels then?
« Reply #5 on: August 13, 2008 - 09:12:52 PM »
The only 833's in trucks that I am aware of were with the slant 6 or 318 and they were the overdrive  version.
« Reply #6 on: August 14, 2008 - 01:57:46 AM »
essentially no the 143 tooth flywheel will not work in a 130 tooth bell
 the 130 tooth flywheel is readily available
Offline bigblue73
« Reply #7 on: August 18, 2008 - 03:40:50 PM »
The part number I believe you need is 3515734.  This should be the 72-73 version of the 4 speed bell housing.  130 tooth for passenger cars.
sleepychallenger
« Reply #8 on: August 18, 2008 - 03:48:40 PM »
how many 130 tooth bell housings are there?
« Reply #9 on: August 19, 2008 - 02:33:16 AM »
ummm Slant 6 , 4.32 dia small block  , 4.80 dia small block , 5.2" dia small block , 4.32 dia big block , 4.80 dia big block , truck a430
