Author Topic: Clutch linkages  (Read 1024 times)
Offline 73EStroker
Clutch linkages
« on: August 13, 2008 - 11:24:42 PM »
When CP and I started my 451 motor we noticed that the clutch pedal was reasonable insofar as pedal pressure to operate is concerned. However, the travel of the pedal does not go to the floor. It goes maybe 3/4 of the way down. With Neil beneath the car he confirmed that the clutch forks are travelling fully in. Now I believe the 340 Z-Bar is longer than the BB setup correct? Mine reaches the bellhousing pivot point and the frame pivot point just right IE not too long or not too short. If it was a small block unit wouldn't that be a different story? CP and I were at a loss to explain this. Only thing that comes to mind is it is a fork off another vehicle. It worked fine with the 340 in there. the clutch is a 3000LB race unit from Ma Mopar and the disc is a McCleod Ceramic.
Barry (Salmon Arm)
Re: Clutch linkages
« Reply #1 on: August 13, 2008 - 11:56:18 PM »
Offline Changin Gears
Re: Clutch linkages
« Reply #2 on: August 14, 2008 - 12:57:10 PM »
I am assuming the pedal will go to the floor without the clutch linkage attached to the fork.  How thick is that ceramic disk?  If it was real thick the finger height of the pressure plate could be to0 low and running out of travel.
Offline 73EStroker
Re: Clutch linkages
« Reply #3 on: August 14, 2008 - 02:31:33 PM »
CG - the disc looked about normal when it was in the box. I did not take actual measurements though. Suppose I could keep a record of adjustments as it may go down fast and need adjusting often. Good point though.
Also thanks bullitt - it looks like I need less leverage on the z-Bar IE get the correct one. But I definetly don't need a shorter tube length or else the torque over of the engine under power may pull the linkage off the bellhousing pivot ball.
« Last Edit: August 14, 2008 - 02:37:43 PM by 73EStroker »
Barry (Salmon Arm)
