Author Topic: 3-speed wipermotor  (Read 2847 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
3-speed wipermotor
« on: August 16, 2008 - 11:26:59 AM »
My GTX -69 has a 3-speed wipermotor that only get started if you kick it with the hammer a couple of times on the motorhousing. Have checked the cables for
corrosion but don't find anything. Any suggestions where to start looking?  :1zhelp:
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Re: 3-speed wipermotor
« Reply #1 on: August 16, 2008 - 11:57:59 AM »
brushes are probably stuck or worn out
« Reply #2 on: August 16, 2008 - 06:01:52 PM »
Will look for a replacement one then. Wouldn't know where to fix it.  :2thumbs:
Offline dutch
« Reply #3 on: August 16, 2008 - 06:19:01 PM »
don`t replace the motor, just the coal brushes...
*** Bart ***
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #4 on: August 16, 2008 - 09:20:29 PM »
You also might want to check and see that you have a good ground. I made the mistake of buying a replacement wiper motor (2-speed) for my '68 barracuda only to find there was nothing wrong with the original......only a bad chassis ground!!! just a thought!! :2thumbs:
                                                      Matt B.
Matt
« Reply #5 on: August 16, 2008 - 10:00:13 PM »
Are the coals special for that motor or could a "normal" carparts shop have them aswell?
« Reply #6 on: August 19, 2008 - 02:24:56 AM »
just remove the 2 long bolts holding the motor together & the brushes are under the end cover
« Reply #7 on: August 19, 2008 - 12:37:49 PM »
Coals were stucked but good, the copper threaded axle (whatever it's name is) is burned. Also the going back contact is burned. Since it's the original and the car is also I would
appreciate if someone knows a good restorer of it.
« Reply #8 on: August 22, 2008 - 01:49:48 AM »
Jules the wiperman is a member here
« Reply #9 on: August 22, 2008 - 11:01:30 AM »
This one I bought for my -68 Charger and thought it would fit the GTX also but not.
« Reply #10 on: August 22, 2008 - 11:03:29 AM »
It needs this model, I guess the linkage must differ between early -68 and the 69-71 models?  :clueless:
« Reply #11 on: August 25, 2008 - 06:13:56 AM »
How do I contact him?
« Reply #12 on: August 25, 2008 - 08:54:24 AM »
« Reply #13 on: August 25, 2008 - 11:45:34 AM »
Thanks.  :2thumbs:
