Author Topic: Would a Shaker hood work with this 6 pack tunnel ram intake?  (Read 1250 times)
Offline hemidude426ci
« on: August 18, 2008 - 05:45:40 PM »
Just wondering if any of you guys have ever ran this intake with a shaker hood, I doubt it would work, but I noticed that my shaker doesn't stick out far enough just on stock intake alone. How much taller would this set up be anyway?  http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=34198&viewitem=&item=130246271143&_trksid=p3907.m29
1970 FC7 440-6 'Cuda 4spd  Track Pack N96
Gone:
1970 Challenger R/T 440 6pack 4 spd N96
1970 Superbee 440 6pack 4 spd
1967 Shelby GT350
Offline 73Chally
Re: Would a Shaker hood work with this 6 pack tunnel ram intake?
« Reply #1 on: August 18, 2008 - 06:15:08 PM »
This can be done, but it is a bit of work.  My buddy did the exact thing on his Cuda using the same intake, but it took a lot of work and fiberglass.  The bubble sits up a lot higher, so a stock one will not fit.  You either have to make your own bubble or cut up a repro.
Offline ladman
« Reply #2 on: August 18, 2008 - 07:13:53 PM »
This will give you some idea about how high up my carbs are above my stock hood.
'73 'Cuda Pro Street
« Reply #3 on: August 18, 2008 - 07:57:46 PM »
Wow ok, thats a bit too high. Thanks for the info guys.
Gone:
1967 Shelby GT350
craigsmytcudas
« Reply #4 on: August 19, 2008 - 11:37:30 PM »
look to your left and there it is on a cuda .also you can go to huls auto works .com and see it up closer .its a cool intake , i also ran one on a 69 rr with a factory lift off hood .the tunnel ram in the other post is not even close .c  :droolingbounce:
Offline nqkjw
« Reply #5 on: August 20, 2008 - 06:52:50 AM »
I've got one of them i'm setting up for my 69 cuda.
Just got the linkages sorted so it is happening although slowly.
Burnouts are cool but Traction is the Action
