Author Topic: AAR/TA Spoiler Installation  (Read 9624 times)
Alaskan_TA
Re: AAR/TA Spoiler Installation
« Reply #15 on: August 20, 2008 - 09:34:14 PM »
The templates from FPAP mentioned above are for marking the cutouts in the underskin.
This is where the 4 clips go - on a T/A, two on each side. AARs are simlilar;
Alaskan_TA
« Reply #16 on: August 20, 2008 - 09:36:55 PM »
Look close at the second photo Confederate Cuda posted as well. See the screws? They pass through the outer edge of the decklid into the four clips mounted in the spoiler tips.
Offline TripleT
« Reply #17 on: August 21, 2008 - 08:13:21 AM »
Ahhh, so the screws actually go through the deck lid and are therefore what "secures" the spoiler to the car so you can't just come by and pop it off the T-bolts....
I'm going to mock up the spoiler and see if I can figure it out.  Thanks Alaskan!
 :clapping: :clapping:
-Tim
1970 Plymouth Barracuda    2000 Dodge Ram 2500
Offline Confederate Cuda
« Reply #18 on: August 21, 2008 - 09:28:15 AM »
Tim,
My deck lid is a 70-71 which had these cutouts from the factory. If you have a later style deck lid you will have to cut these out yourself. The T bolt will lock into the spoiler and then you will have to drill holes in the deck lid for the bolt to go through and the cone shaped nut will secure it to the deck lid. Just as Barrys picture shows the clips are for the outside screws that go through the deck lid and into the clip that is mount on the spoiler. Good Luck
Offline TripleT
« Reply #19 on: August 21, 2008 - 12:37:11 PM »
Gents- your pictures have made it clear.  I understand completely.  My spoiler does indeed have the 2-on-each-end rectangular cut-outs, which is where the clips go.  You guys have been very patient, thanks very much.  I'll post a pic or 2 when I get it on.  Thanks again fellas.      :worshippy :worshippy
Tim
Although 8 holes to drill in a deck lid does seem a bit excessive (4 for the clips, 4 for the T-bolts).  I cringe at drilling holes in the body.  Must be all that high MOPAR speed requires it.
« Last Edit: August 21, 2008 - 12:39:48 PM by Seamus »
-Tim
Offline rilko
« Reply #20 on: April 19, 2011 - 12:09:54 PM »
Hi All .. can anyone repost the pics re: TA duck tail spoiler install? I understand how the hardware works but looking
for correct placment. I'm thinking I will try and make my own transparent mount template for correct hole placement
from top of deck lid. THANX!
Offline darkhawk
« Reply #21 on: May 03, 2011 - 01:25:40 PM »
 :popcorn: bump  :popcorn:
Nigel
73 Cuda
65 Valiant Convertible
04 Dakota
Offline Barracudadan
« Reply #22 on: May 03, 2011 - 02:31:42 PM »
I would be interested in this as well. I will be putting a duck tail on soon and could use a little help too. Thanks!
