Author Topic: What size NGK plugs should i try?  (Read 1075 times)
Offline wally426ci
    • maryland mopars
« on: August 20, 2008 - 05:27:39 PM »
Its about time i start working on my car instead of just driving it. After getting it running right, i just cant stop. But i need to get on a few things. I was gonna try out some other plugs for my 408 stroker.... Im running Champion RN12YC i think its RN.....
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline 71chally416
    • The Streetwalker
Re: What size NGK plugs should i try?
« Reply #1 on: August 21, 2008 - 12:54:54 AM »
That would be BPR5ES for resistor plugs.
You should be flogged for using Champion plugs  :grinno:
« Reply #2 on: August 21, 2008 - 02:09:36 AM »
My bet is if you can tell the difference at all it will be worse
Offline Aussie Challenger
« Reply #3 on: August 21, 2008 - 05:08:33 AM »
  I would use BPR5EY for cruising and BPR6EY highway and traffic light derby's.
  The "Y" means that the electrode has a "V" groove and it gives a better spark and are the same price as the "S" plugs. I only use NGK now days because they are so reliable and no come backs.   :2thumbs:   :bigsmile:
Offline Mike70
  • Future Challenger Pilot
« Reply #4 on: August 21, 2008 - 10:15:12 AM »
Way back when, Champion was all I ever put in my Challenger. Chryco, are you saying that the NGK will be worse? So you like Champion also?
70 Challenger RT/SE
(If I ever get it done - wait, I guess I have to start first).
« Reply #5 on: August 21, 2008 - 12:20:35 PM »
Yeah I use Champion , , I have always had fouling problems with NGK but only if the mixture is off or the choke fouls the plug then they quit firing.
 a few years ago we did a dyno test with all the major brands of spark plugs looking for every last HP in a race engine & it was proven that the cheapest plugs made the most power & the more the plug cost the less power it made
Offline wally426ci
    • maryland mopars
« Reply #6 on: August 21, 2008 - 12:59:57 PM »
 :clueless: Interesting..... I had always heard good about NGK... ah, maybe i'll pull em and see what they look like....  :dunno:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline 71chally416
    • The Streetwalker
« Reply #7 on: August 21, 2008 - 03:20:41 PM »
Here's an interesting sparkplug dyno test they did on stock SRT-4. Being that it's only a 4 banger you can probably expect twice the gain on a V8. Best numbers are indicated in red.
http://www.srtforums.com/forums/f308/srt4-sparkplug-shootout-dyno-results-409262/
Offline wally426ci
    • maryland mopars
« Reply #8 on: August 21, 2008 - 04:37:11 PM »
:popcorn:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline 74 340 4speed
« Reply #9 on: August 21, 2008 - 08:02:28 PM »
I've run Champion, Autolite and NGK in my 340.  The champions would foul out in 3 trips around the block.  The autolites lasted about 5 trips. I put the NGK's in almost a year ago now and haven't had any problems since.  I think I have BPR6ES if I'm not mistaken.  I crossed the champion # that I originally run to the autolite plug first, then crossed that to the ngk plug.  To my knowledge, I didn't change the heat range.  I went by what the books told me.
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
« Reply #10 on: August 21, 2008 - 08:17:28 PM »
I run autolite 85's in my 440-6. They have been in there since new. I run a point ignition system. Runs good cold or hot. I havent had an issue. I run stock ignition wires with it also.
