Author Topic: Door hinge  (Read 829 times)
Offline MoparGene
Door hinge
« on: August 20, 2008 - 09:11:52 PM »
Iv'e been living with it for too long now, my drivers door doesn't shut right unless I pick up on it and slam it.I'm fairly new to the e-bodies , is there a way to ajust the hinge ?or do I need to just put another one on?
Offline Katfish
  • 70 Challenger
Re: Door hinge
« Reply #1 on: August 20, 2008 - 09:35:19 PM »
I think this is what you need.
http://www.cuda-challenger.com/cc/index.php?topic=48442.0
I have the same problem with my door.
Re: Door hinge
« Reply #2 on: August 21, 2008 - 01:52:16 AM »
it is adjustable , but the bolts are difficult to get at , you need to pull the kick panel to get to the lkower bolts & go behind the dash to get the upper hinge bolts , to make things woirse some are facing inside & some outside , make sure the pins are ok Before adjusting though
