generally I have not hurt them as long as you get the timing advanced immediatly & adjust the mixtures to be sure it is not lean while doing the break in , usually I can tell if the engine needs larger jets during the break in if the engine smooths out with the mixture screwws turned out during the break in & need to be adjusted in at idle
