Hooker Header ?
Author Topic: Hooker Header ?  (Read 9679 times)
Offline tactransman
Hooker Header ?
« on: August 21, 2008 - 12:08:23 PM »
I have Hooker Super Comp headers for my car,I traded them for some trans work three years ago. I have never seen a driver side header that the front suspension did not go thru the header tubes,has any one ever had a header like this on an E body driver side?
These are what I have always seen:
Terry-tactransman
Union, Mo.
Offline pink panther
Re: Hooker Header ?
« Reply #1 on: August 21, 2008 - 12:26:49 PM »
I chave hooker super comps, I can look tonight and see if they look like that
Re: Hooker Header ?
« Reply #2 on: August 21, 2008 - 12:32:02 PM »
Hooker does have a different # for the small block like the ones you have , obviously that is what I would be using
Offline tactransman
Re: Hooker Header ?
« Reply #3 on: August 21, 2008 - 12:37:06 PM »
Do you know what the part # is CP?
Terry-tactransman
Union, Mo.
Re: Hooker Header ?
« Reply #4 on: August 21, 2008 - 12:37:50 PM »
I can look it up
Offline tactransman
Re: Hooker Header ?
« Reply #5 on: August 21, 2008 - 12:39:27 PM »
Thank You!  :cheers:
Terry-tactransman
Union, Mo.
Re: Hooker Header ?
« Reply #6 on: August 21, 2008 - 12:43:06 PM »
Could be the 5115 HKR but there is nop pic in their catalog for that header  :banghead:
Offline 71chally416
    • The Streetwalker
Re: Hooker Header ?
« Reply #7 on: August 21, 2008 - 12:50:33 PM »
I have those on mine and the drag link doesn't go through the pipes. I believe they are the 5115's
« Last Edit: August 21, 2008 - 12:53:25 PM by 71chally416 »
Offline tactransman
Re: Hooker Header ?
« Reply #8 on: August 21, 2008 - 12:56:15 PM »
CP I see now on the back of the flange that it says 5115! Thank you! Now I know what I have.  :clapping:
Terry-tactransman
Union, Mo.
Offline tactransman
Re: Hooker Header ?
« Reply #9 on: August 21, 2008 - 12:56:54 PM »
Have you had them on/in the car yet? Clearance? Nice look'in engine by the way!  :burnout:
Terry-tactransman
Union, Mo.
Offline tactransman
Re: Hooker Header ?
« Reply #10 on: August 21, 2008 - 01:06:49 PM »
By the way,what do you all do about this info given on the Hooker site? I am gonna have to break in my new Voodoo cam and only have this set of headers. :eek7:
Installation Notes
Breaking in an engine with ceramic coated Headers WILL result in damage to the coating and will VOID all warranties. Ceramic coated Headers require several heat cycles to fully cure before they will withstand extreme heat. Hooker recommends using cast iron exhaust Manifolds or old Headers to break in new engines to avoid coating damage. Please call Hooker tech service at 270–781–9741 for additional information regarding ceramic coated exhaust products.
Terry-tactransman
Union, Mo.
Re: Hooker Header ?
« Reply #11 on: August 21, 2008 - 01:38:11 PM »
generally I have not hurt them as long as you get the timing advanced immediatly & adjust the mixtures to be sure it is not lean while doing the break in , usually I can tell if the engine needs larger jets during the break in if the engine smooths out with the mixture screwws turned out during the break in & need to be adjusted in at idle
Offline 71chally416
    • The Streetwalker
Re: Hooker Header ?
« Reply #12 on: August 21, 2008 - 01:40:41 PM »
They fit fine in mine and I have power steering. Even the mini-starter drops right out if it ever needs to be changed.
Re: Hooker Header ?
« Reply #13 on: August 21, 2008 - 01:41:38 PM »
the bad part is it still traps #5&7 plugs with the pipe over the top
Offline tactransman
Re: Hooker Header ?
« Reply #14 on: August 21, 2008 - 02:06:56 PM »
That sounds encouraging!  :clapping:
I can live with that!  :grinyes:
They are a $700 set of headers that I got for $300 trade in trans work.
Terry-tactransman
Union, Mo.
