Author Topic: Cuda Louvers  (Read 737 times)
Offline MR291
Cuda Louvers
« on: August 22, 2008 - 08:46:53 PM »
I am looking to add rear louvers to the Cuda and was looking to get some opinions on what it takes to install these and if possible can someone post some pictures or email them to me.  Before I start making holes in the car I want to be sure this is going to work well.  There is a place outside of Montreal that produces these.  A complete kit for $1,100.00.  Is this a reasonable price?  Saw them at the New Hamburg MOPARFEST and they looked great.
Appreciate it.
Offline hotrod98
    • Maniac Musclecars
Re: Cuda Louvers
« Reply #1 on: August 22, 2008 - 09:52:09 PM »
When I installed mine, I installed nut serts into the roof for the hinge screws. I didn't want sheet metal screws holding my original louvers on the car.
I just set mine in place and once positioned, I marked the location of the hinge holes by placing masking tape on the roof and then used a marker to mark the hole locations on the tape. After drilling the holes, I then used a nutsert tool to install the threaded nutserts. After installing the louvers, I then located the lower pins using a similar procedure. Be sure and use sealant at the upper screws and lower pins (hood pins).
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
