Author Topic: Pegged Oil Pressure Gauge  (Read 628 times)
Offline troutstreamnm
« on: August 22, 2008 - 11:29:00 PM »
I fired up and broke in my big block this week and all went well  :cooldancing:  The new Redline electric oil pressure gauge I installed immediately went to 80 psi + reading evening when priming the motor with the priming tool.  When the motor is running, even at idle, the guage is pegged and doesn't seem to move until the power is cut off.  Is this something with the sending unit, calibration, grounding, or with the engine?  The engine builder did help me with the break-in and indicated the motor was very tight so he was not real concerned with the pressure.  Comments?
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Re: Pegged Oil Pressure Gauge
« Reply #1 on: August 23, 2008 - 12:33:25 AM »
the high pressure pump will make 80-105psi which is more then the guage si calibrated to read , the engine however is normal
« Reply #2 on: August 23, 2008 - 09:32:35 AM »
Thanks CP...you are correct it does have a HP oil pump.  I should have figured that one out myself  :-[
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Offline MJS73
    • Mike's 1973 Challenger
« Reply #3 on: August 23, 2008 - 11:24:16 AM »
I have the same gauge/pump configuration and mine does the same thing.
www.mikes73.com
« Reply #4 on: August 23, 2008 - 11:44:32 AM »
Wonder what the pressure really is. You may want to get a bigger gauge. I would be concerned with it wearing out the bronze bushing or distribor shaft prematurely. You may even blow the seal in the oil filter. It could be a problem that is easly fixed.
