Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
bumping under car transmision mount
« previous
next »
Print
Pages: [
1
2
Author
Topic: bumping under car transmision mount (Read 3056 times)
mikerallye
Jr. Member
on:
August 24, 2008 - 11:40:20 AM »
Starting to notice a bumping under the console. Probably the trans mount. Can the rubber bushing be changed or does the whole mount have to be changed? Is this something I can get from a major supplier? thanks
Logged
wally426ci
Sr. Resident
Re: bumping under car transmision mount
Reply #1 on:
August 24, 2008 - 11:49:59 AM »
I just thought id ask, where is a good source to get the mount? hope im not hijacking.
Logged
{OOI====I====IOO}
'71 Challenger
[O[]=====[]O]
'68 D100
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Reply #2 on:
August 24, 2008 - 12:06:08 PM »
three options at Auto Zone
http://www.autozone.com/N,11200166/shopping/partTypeResultSet.htm
http://www.autozone.com/R,1760856/vehicleId,1470712/initialAction,partProductDetail/store,31/partType,00166/shopping/partProductDetail.htm
Picture is inaccurate...you get two round bushings & metal sleeve to install in your OE bracket
Energy-Suspension / Transmission Mount - Performance
5.1101G
http://www.autozone.com/Ntt,5.1101G/shopping/allResults.htm
Last Edit: August 29, 2008 - 09:42:52 AM by bullitt99
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
August 24, 2008 - 12:11:37 PM »
energy suspension makes the Poly insert for the stock mount
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #4 on:
August 24, 2008 - 12:45:07 PM »
Check your front U-joint while you are under there.
Tom
Logged
Tom
mikerallye
Jr. Member
Reply #5 on:
August 24, 2008 - 01:17:11 PM »
Will do, thanks all, headed to AZ now.
Logged
GoodysGotaCuda
Sr. Resident
Reply #6 on:
August 24, 2008 - 01:49:24 PM »
i've heard the inserts are a pain to swap out, the couple i've changed, i just spent the couple bucks and got the entire mount. Less headaches.
Logged
Build Page:
Goody's 'Cuda Build Page
1976 Dodge Warlock
Wheel & Tire Specs:
Link
Katfish
Resident
70 Challenger
Reply #7 on:
August 24, 2008 - 01:53:43 PM »
Couldn't agree more, it is a major pain to remove the old rubber. Just buy the whole mount, money well spent!
http://www.cuda-challenger.com/cc/index.php?topic=36797.0
Last Edit: August 24, 2008 - 01:56:51 PM by Katfish
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #8 on:
August 24, 2008 - 01:57:42 PM »
heat them with a Propane torch the rubber will become slippery & slide out
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #9 on:
August 24, 2008 - 07:39:16 PM »
I put the poly mount in, now that was tight.LOL
There wasn't much of the rubber left to get out.
Tom
Logged
Tom
wally426ci
Sr. Resident
Reply #10 on:
August 25, 2008 - 07:01:09 AM »
About 7 years ago, i got one from Salvo Autoparts and the holes didnt line up.... anyone know if the Autozone (entire mount) one works? or do you have a link to the rubber mancini one? i go there and there are no pics or good descriptions...
Logged
{OOI====I====IOO}
'71 Challenger
[O[]=====[]O]
'68 D100
Chryco Psycho
Administrator
C-C.com Guru
Reply #11 on:
August 25, 2008 - 12:09:27 PM »
the car & truck mount look the same but are at different angles , possibly you got the truck one
Logged
wally426ci
Sr. Resident
Reply #12 on:
August 25, 2008 - 12:38:27 PM »
they used to be like $55 from year-one so hopefully this works...
Logged
{OOI====I====IOO}
'71 Challenger
[O[]=====[]O]
'68 D100
Katfish
Resident
70 Challenger
Reply #13 on:
August 25, 2008 - 05:17:15 PM »
Try Summit
http://store.summitracing.com/partdetail.asp?autofilter=1&part=PTP%2D4%2D1603%2DBL&N=700+4294848530+4294925081+4294908110+115&autoview=sku
Logged
wally426ci
Sr. Resident
Reply #14 on:
August 26, 2008 - 07:25:52 AM »
I would think if one were to run a poly trans mount, you would want poly engine mounts? I wouldnt think you would want to mix it up?? hope im not hijacking, i just figured it would be a good post to talk about this in....
Logged
{OOI====I====IOO}
'71 Challenger
[O[]=====[]O]
'68 D100
Print
Pages: [
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
