Author Topic: bumping under car transmision mount  (Read 3053 times)
Offline heminut
Re: bumping under car transmision mount
« Reply #15 on: August 26, 2008 - 10:50:58 AM »
I've been running a poly tranny mount with stock rubber engine mounts for 6-7 years now with no problems. I do have a chain on the driver's side of the engine to keep from tearing the left mount apart, but it has enough slack in it that the engine moves some.
1970 5.7 Hemi Cuda
Offline 422STROKER
  • Member Since 6/3/06
« Reply #16 on: August 26, 2008 - 04:20:34 PM »
I would think if one were to run a poly trans mount, you would want poly engine mounts? I wouldnt think you would want to mix it up?? hope im not hijacking, i just figured it would be a good post to talk about this in....  :swaying:
I run the poly trans as well with rubber engine mounts, no problems as far as I can tell.
Tom
Tom
Offline wally426ci
    • maryland mopars
« Reply #17 on: August 27, 2008 - 06:14:15 PM »
Hmmm... I was also thinking that even the rubber interlocking engine mounts would be too stiff b/c it sounds like the bolt all the way through... So, wouldnt there be no flexing?? I just want to make sure the car doesnt rattle apart.....  :working:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #18 on: August 28, 2008 - 03:22:40 AM »
the car will absorb a ton of engine vibration with near solid mounts , the interlocking mount is virtually a must a the least vibration transmission , any soild torque strap will transmit more vibs
Offline Aussie Challenger
« Reply #19 on: August 28, 2008 - 05:56:02 AM »
  I bought my poly mount from Brewers, bolted straight in, even though I have access to a press I found it much easier to buy the whole mount.   :cheers:
Offline mopower
« Reply #20 on: August 28, 2008 - 08:13:36 AM »
before you buy id check your moter mounts, my tranny was beating the hell out of the floor and ended up being motor mounts. went with the poly locs...priceless :2cents:
Offline wally426ci
    • maryland mopars
« Reply #21 on: August 28, 2008 - 05:13:49 PM »
 :chatting: Neal, it looks like you were typing with your Thumbs again, can you rephrase this?  :crazy:
Are you guys thinking i should by the bolt through rubber engine mounts and a poly trans mount or stock rubber mounts and a poly trans mount? or what?
:dunno:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline 422STROKER
« Reply #22 on: August 28, 2008 - 07:14:18 PM »
If I were to do it again I would get the interlocking mounts and the poly trans as well.  I notice no harshness from the trans and have stock rubber to worry about at the motor.  If you are going to change them go for the 60 dollar stuff not the 6 dollar stuff like me.LOL
Tom :smilielol:
Tom
Offline wally426ci
    • maryland mopars
« Reply #23 on: August 28, 2008 - 08:02:04 PM »
wierd, i click on those Autozone links now and it gives me a Dash Cover....  :dunno:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #24 on: August 29, 2008 - 09:44:01 AM »
I fixed....they must be doing some maintenance
