twiles,
If you have the radiator and have it recored with 3 rows of tubes like Moparal described, that's probably the cheapest solution. Since the original radiator in my Challenger was long gone when I bought it, I had to find a replacement radiator. That's why I went with the radiator from Coolcraft. I opted for the 4 row core and it does keep the motor around 180 deg. The part number is 036042. The fan shroud mount is part of the radiator side brackets and you can bolt the factory shroud to it.
Aside from the rather steep price, my main complaints are the incorrect orientation of the overflow tube. Instead of the tube being angled directly to the side of the radiator, it is angles towards the engine a little bit. This makes the overflow hose loop towards the engine a little before it goes down the side of the radiator. If you want pics, let me know. Hope this helps.
