Author Topic: PS pressure line for a small block with a Federal pump  (Read 767 times)
Offline Ornamental
  • Oslo, Norway
« on: August 25, 2008 - 07:20:56 AM »
I got a Federal servo pump, not a Saginaw. Apparently, the pressure line to be replaced isn't stock for a E-body:
Year One lists this as a line for 70-72 B & E-bodies with a small block and a Federal pump:
http://www.yearone.com/serverfiles/fbshopmain2.asp?pid=FD323&c=0&e=0&cat=1&hid=119AB5119&trk=
It doesn't really look like it would fit, but does it?
Who here got the same set-up as I do, and what pressure line do you use?
Panther Pink '72 Challenger Rallye.
Grey '70 Challenger R/T
-There are two kinds of pedestrians: The quick and the dead.
***Per Arne***
Offline Ornamental
  • Oslo, Norway
Re: PS pressure line for a small block with a Federal pump
« Reply #2 on: August 25, 2008 - 10:23:52 AM »
Thanks Bullitt!
Do you have something similar in your Chally?
***Per Arne***
« Reply #3 on: August 25, 2008 - 11:07:46 AM »
It kinda looks like you installed the hose upside down
« Reply #4 on: August 25, 2008 - 02:54:13 PM »
Thanks Bullitt!
No I've got a Saginaw pump
Offline Ornamental
  • Oslo, Norway
« Reply #5 on: August 25, 2008 - 06:23:01 PM »
Found a tech article about servo pumps:
http://www.bigblockdart.com/techpages/pspumps.shtml
And a website that claims to have a hose for my set up, part# 80119 seems to be the ticket to end my power steering woes:
http://www.autopart.com/partsout/1972/DODGE_CHALLENGER/7318.htm
I can see why you would think that. :D
But, not so many other practial ways to do it.
***Per Arne***
