Author Topic: E Body SS Spring install...  (Read 2477 times)
Offline mopar_440_Challenger
« on: August 25, 2008 - 07:45:56 AM »
Hey all,
   I just had a quick question - in order to install the SS Springs on a '70 Challenger, I see where it calls out for offset front hangers, but I was wondering if offset rear shackles will also be req'd?? On the Mancini page, it only says B Bodies will need both...any truth to the rumors?? Thanks everyone!!
        -Chris
Offline GoodysGotaCuda
Re: E Body SS Spring install...
« Reply #1 on: August 25, 2008 - 07:56:02 AM »
Well you don't quite need offset front hangers, you need longer front hangers since the springs are designed for abodies. Stock style rear shackles will work just fine.
They should be pretty much like these
"Product Description
These straight hangers are 2.0" longer for use with Super Stock springs"
"MOPAR - Front Hanger Bracket Sets
Front Hanger Bracket Set -- 108/110/115" WB (1964-65 Mod. B-Body, 1970-74 E-Body, 1971-74 B-Body Hard Top)
$64.95
MOPP4120080"
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline ShelbyDogg
« Reply #2 on: August 25, 2008 - 04:47:46 PM »
The front hangers for super stock springs on an e-body are offset AND extended 2 inches. Springs in an ebody aren't parallel to the frame, they are wider on the rear for handling. Installing the offset front hangers, sets them up straight. So the picture above isn't for an e-body. It is just a stock photo.
Offline Katfish
  • 70 Challenger
« Reply #3 on: August 25, 2008 - 05:36:05 PM »
This is what you need
Front 4120078
Rear 4120076
Offline heminut
« Reply #4 on: August 25, 2008 - 05:43:03 PM »
That's not correct, I used those hangers in my 70 Cuda and everything bolted up just fine! You use the offset front hangers and rear shackles if you want to move the springs inward from the stock location, and if doing so you will also have to relocate the spring perches on the axle housing.
1970 5.7 Hemi Cuda
« Reply #5 on: August 25, 2008 - 06:02:34 PM »
Front 4120078
Rear 4120076
That kit is to move the springs in and the perches
Offline 360 'CUDA
« Reply #6 on: August 25, 2008 - 06:22:47 PM »
Just to clarify the kit Goody is showing does allow the installation of SS springs. That's OK if you stick with the stock rearend  BUT, the setup you want is the one that katfish is showing. It straightens the springs, allows the use of SS springs and moves the springs in a little less then an inch.
That allows the use of a stock 1967 - 1970 B-body rearend that just bolts right in.  The advantage is you get more room inside the wheelwell for bigger tires.  As shown on my '74
« Last Edit: August 25, 2008 - 06:46:48 PM by 360cuda »
Offline ShelbyDogg
« Reply #7 on: August 25, 2008 - 08:02:22 PM »
Okay, My BAD.  I just never had any friends that didn't use the offset shackles when drag racing the super stock springs.  Probably because of the alignment thing.
Offline Changin Gears
« Reply #8 on: August 25, 2008 - 08:31:41 PM »
The offset shackles and hangers allow you to intall a b-body rear in an e-body.  If you do this you have to oblong the spring center holes in the perches about 1/8th inch and use 2 degree shims to correct pinion angle.  This is a great swap thats easy to do.
Alaskan_TA
« Reply #9 on: August 26, 2008 - 11:46:54 PM »
I have a set of the straight ones here, 35 bucks plus postage.
 mopar_440_Challenger has first crack at them since he started the thread, email me within three days please if interested?
Barry
Offline 71chally416
    • The Streetwalker
« Reply #10 on: August 26, 2008 - 11:55:32 PM »
Yep, for whatever reason they put the leaf springs in crooked in the E-bodies. Supposedly for "better handling".  :dunno:  You might also have
issues with the brakes lines. I seem to remember having to relocate them on a customers car I did this too, but I fabricated my own front hangers, so the factory parts might clear.
Alaskan_TA
« Reply #11 on: August 31, 2008 - 09:24:14 PM »
I have not heard from him, so if some one else needs these, they are still available.  :wave:
Offline Aracer
« Reply #12 on: September 06, 2008 - 12:04:25 AM »
     When I was using the SS's I had to relocate the fuel line. It ran under the perch. Don't laugh but I used the straight Mopar SS hangars and the offset hangars. The trick was to use the 1/2" bolts in the 5/8" holes.This allowed the the springs to seat in the perches without filling the holes. There was no wear indicating  movement, when I removed them.
