Author Topic: in the process of removing camshaft need help  (Read 9078 times)
Re: in the process of removing camshaft need help
« Reply #45 on: September 02, 2008 - 06:12:46 PM »
Install it, then degree it to see if it's to spec :2thumbs:
« Reply #46 on: September 02, 2008 - 06:16:11 PM »
the teeth do not line up , line up the dots , degree it & change it if nessisary , the other marks either advance or retard the timing 4*
Offline 73 challenger 440
« Reply #47 on: September 02, 2008 - 06:17:10 PM »
thank you for your fast reply..WOW!
« Reply #48 on: September 02, 2008 - 06:24:58 PM »
well you are welcome & lucky I am online right now
« Reply #49 on: September 02, 2008 - 07:01:41 PM »
ok, got them on.. but it was hard to get these marks lined up the way they are.. in the pic it looks like the lower dot isn't completley strait up.. there is so much slack in this chain on both sides... it's cloyes part number 9-3104 ... if I change it just one tooth the marks will be off much more..
« Reply #50 on: September 02, 2008 - 07:05:37 PM »
Are both sprockets seated all the way on the crank and cam?   Has the block been line boredL  Looks like it has if all is seated.
Offline hemiken
« Reply #51 on: September 02, 2008 - 07:08:53 PM »
That picture does not look quit right.  Any chance you can take a picture with the camera horizontal to the block and dead inline, to me you look to be one tooth out. :2thumbs:
« Last Edit: September 03, 2008 - 07:13:35 AM by hemiken »
« Reply #52 on: September 02, 2008 - 09:10:22 PM »
yea, they are now :-[..
chain is tight.....
I had my Dad hold a ruler while I took the pics, kinda hard to do this.. it's off just barley..
in the second pic thats how they line up if the ruler wasn't there but the chain is tight now..
Offline hemiken
« Reply #53 on: September 03, 2008 - 07:17:58 AM »
I still think you are a tooth out...........
Rotate the bottom dot a little more and hold the ruler to line up through the bottom snout and throught he middle of the dot and then the middle of the cam bolt, i am thinking it looks a little out from here.  ;)
« Reply #54 on: September 03, 2008 - 01:24:32 PM »
I set the old gear over the new one, and the old is dead strait up.. you can see the new one behind it is just off to the right.. but I'll give it a shot. the red tube you see in the pic is sitting right on the dot on the new set. on the old gear you can see where I put some green paint on the timing dot.
Offline tactransman
« Reply #55 on: September 03, 2008 - 03:02:36 PM »
It looks good to go to me. It looks like the block has been line bored though.
« Last Edit: September 03, 2008 - 03:04:18 PM by tactransman »
Terry-tactransman
Union, Mo.
« Reply #56 on: September 03, 2008 - 06:08:43 PM »
well here I am again.. I called cloyes tech line yesterday and today, I guess there tech line goes to one person, because it's says mike is not available to leave a message >:(
but I found a much easier way to see if the dots line up, I put the top gear on a secured bolt or a wire, then put the bottom gear on and no matter what the dots are not lining up, it either goes to the left or right one tooth..
but here is there instructions. notice they marks how it shows on the page is not how they are on the gears
« Reply #57 on: September 03, 2008 - 06:11:29 PM »
I want to order another set.. anyone know of a good double roller without the 3way  offsets..
Offline 422STROKER
  • Member Since 6/3/06
« Reply #58 on: September 03, 2008 - 06:21:33 PM »
So you can't get the dots to line up even laying on a table?
Tom :clueless:
Tom
« Reply #59 on: September 03, 2008 - 06:27:48 PM »
I tried the table. and it's quicker and more acurate doing it the way I descibed.. I am guessing perhaps they put the wrong set in the box.. dont know how that can happen if it's automated..
