Author Topic: in the process of removing camshaft need help  (Read 9090 times)
Offline 73 challenger 440
« on: August 25, 2008 - 05:03:52 PM »
ok, here's my first obstacle. this pipe for the heater core.. how does it come out?? I tried a monkey wrench and it doesn't want to budge.. can it be heated??
Offline Moparal
Re: in the process of removing camshaft need help
« Reply #1 on: August 25, 2008 - 05:06:38 PM »
You know you can leave it on, take an open 9/16 wrench behind it and unscrew the bolt. Many have done this before. Leave a top bolt on the otherside unscrewed out 3/4 of the way to keep it balanced. Your choice to remove the pipe once out or just work around it as others do.
Offline 71chally416
    • The Streetwalker
« Reply #2 on: August 25, 2008 - 05:33:57 PM »
 :iagree:
« Reply #3 on: August 25, 2008 - 05:39:22 PM »
thanks guys... I'll work around it..
« Reply #4 on: August 25, 2008 - 06:00:31 PM »
well another issue.. I dont have the socket to fit the balancer bolt, that thing is huge.. anyone know what size it is?
Offline Moparal
« Reply #5 on: August 25, 2008 - 06:06:41 PM »
1 1/4
Offline Moparal
« Reply #6 on: August 25, 2008 - 06:07:20 PM »
take the pulley off and use a wrench. Or even a big cresent wrench
Offline NoMope Greg
« Reply #7 on: August 25, 2008 - 06:08:42 PM »
Or use this as an excuse to go buy more tools!  :bigsmile:
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #8 on: August 25, 2008 - 06:11:20 PM »
Ilike the excuse... thanks guys
Offline 500Stroker
« Reply #9 on: August 25, 2008 - 07:27:44 PM »
Mine is 1 1/16   :dunno:
« Reply #10 on: August 25, 2008 - 08:45:23 PM »
ok, enough for today.. get back on it after work tomorrow.. here are some pics. the chain I think had a lot of slack.. I am going to get a new chain and gear set.. will any 3 bolt do? I just have to be sure I order a am with 3 bolts as well.. is that correct?
Offline Moparal
« Reply #11 on: August 25, 2008 - 10:44:59 PM »
Now yer getting tricky when it comes to cams and chains. Can you centerline a cam?  If yer not going to, then you really really need a quality acurate well built chain set and then it is still daring.  Good night :bigsmile:
« Reply #12 on: August 26, 2008 - 03:33:29 PM »
I am geting the cloyes souble roller.. is there any timing cover issues with this part?? also I pulled number one plug and cranked the engine over, untill the compression pushed my finger off the hole.. I did this twice and the marks as shown.. crank dot is facing up at 12:00 and the cam sprocket dot is at 12:00 as well is, this correct?
Offline 71chally416
    • The Streetwalker
« Reply #13 on: August 26, 2008 - 03:45:35 PM »
NO!!  The cam dot has to be at 6:00 and the crank at 12:00!!
« Reply #14 on: August 26, 2008 - 03:57:57 PM »
(thats what my Dad said....)  just want to double check..the rotor is off by one spot on the cap. but this seems to be the only way I feel the compression on the motor... I am going to check it again..
