Author Topic: Just a relaxing Sunday cruise...............  (Read 1589 times)
Offline cudadave72
  • you motorboatin sob!!!
Re: Just a relaxing Sunday cruise...............
« Reply #15 on: August 29, 2008 - 09:28:27 PM »
My radio doesn't work.  Since it was primarily a race car since 2000 it didn't matter.  Now on the street up around 85-90 @ 4 grand it sounds so sweet I don't care...
Yeah it does sound great just not so good for the valve train for extended cruising and since I drive mine quite a bit an extra gear would not only make my engine happier, I wouldnt mine the gas savings either. I live by the strict rule of keeping the rpms under 3k on extended driving which leaves me driving in the slow lane on the highway at about 65 mph. :eek4:
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline salem1912
« Reply #16 on: August 29, 2008 - 09:46:56 PM »
500Stoker  Where and went was the show? I just took my kid up to Bloomsburg University last week, I would have loved to stop bye.
Offline 500Stroker
« Reply #17 on: August 30, 2008 - 04:09:55 PM »
White Haven, PA. It's their yearly town festival. "The Jam Below the Dam"  http://www.whitehaven.org/festival.html
Offline BoughtItNew
  • Barracuda
« Reply #18 on: August 30, 2008 - 05:05:12 PM »
It is correct that sustained high rpm is a valve spring killer but here's a surprise...
I spent some time working with NASCAR teams and with CV Products in NC a few years ago.  I learned steady speeds are far easier on valve springs than continuous RPM changes.  For example, there were more valve spring failures at Michigan than Daytona or Talladega.  Longer tracks like Charlotte are easier on them too as the range in speed was somewhat easier.  Martinsville (two drag strips with a corner at each end) was absolutely killer!  Believe it or not, good synthetic oil carrying the heat off the springs extends life too.  Oil spray bars in the valve covers are often used for that.
I have replaced the springs once but attributed that to several hundred drag runs.
It is rare that I get to run more than 65 or 70 for more than a few minutes anyway but it sure sounds good when I do!
Mike Tritle
DeKalb, IL 60115
Original Owner
74 Barracuda
Purchased Sept. 10, 1974
DesPlaines Chrysler Plymouth
DesPlaines, IL
