Author Topic: Aftermarket Quarter Replacement - Need an opinion  (Read 976 times)
Offline Marty73
  • '73 Challenger
« on: August 26, 2008 - 07:53:08 AM »
So I put a new quarter on my 73 Chally last month and in the process of blending/finishing I see that the trunk pan extension lip is shorter than the quarter panel lip (behind the rear tire at the bottom). A family member sent me a pic of his all orginal 74 (he's a member here also) and it looks like a welded accross the bottom seem. But he's in Vermont and I'm in SC - so I can just run over and compare
and I think I'm the only owner of an e-body in surrounding 100 miles.....
Okay to the question/opinion should I "wrap" the extra metal over the extension lip, or just cut if off flush?. Folding/wrapping it over seems like it would be stronger - but I'm also thinking it would make a nice lip to catch water and grime.  I'm going to have to put a new quarter on the drivers side later this year and want to do it the same way and am wondering if the other quarter will have the same extra metal (Goodmark for the curious)
Little detail - but I want to restore this car the right way
Comin' at ya like a herd of turtles
Offline Kapteenikosmos
Re: Aftermarket Quarter Replacement - Need an opinion
« Reply #1 on: August 26, 2008 - 08:34:24 AM »
I would cut the lip on the  quarter so that it matches the trunk extension and spot weld it there. Thats how mine was from the factory if I recall right. In my case I spotwelded the panels together and after that welded the whole edge shut so the water has no way to get inside the seam from the underside, although I still have the problem if the water gets inside the trunk.
After the repairs&paint is done I would also spray some thin oily stuff from the inside of the trunk to the spotwelded seam between the extension and quarter to prevent it rusting again.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
« Reply #2 on: August 26, 2008 - 11:27:42 AM »
I feel the folded lip will casue more issues in the long run unless it si extremely weel seam sealed to prevent rust
Offline 71ChallengerSE
« Reply #3 on: August 26, 2008 - 11:53:36 AM »
There was another Challenger in SC......................................but I bought it and brought it to VA :bricks1:
Offline Marty73
  • '73 Challenger
« Reply #4 on: August 26, 2008 - 12:02:52 PM »
I'm still amazed at how few of these cars are out there compared to all the fords & chevy's -
Offline Marty73
  • '73 Challenger
« Reply #5 on: August 26, 2008 - 12:04:04 PM »
So cutting the excess off is it, time to get out the rotary cutter!
