Hi,
This past weekend, I had my 73 Cuda 340 on the highway to go to a show about 35 miles away. I noticed that at highway speeds (65-70 mph), the temperature gauge would creep up to about the 2/3 mark on the gauge. This is still within the normal range on the gauge, but it's getting near the upper limit.
Here are some specifics about the car that may help: The 26 in. 2-row brass replacement radiator is about 2 years old and the tubes look clean. There are no visible leaks anywhere in the cooling system. The hoses are about 1 year old. I use a 50/50 mix of coolant with a bottle of water-wetter thrown in. I installed a 160 deg. thermostat when I changed the hoses. At idle or in city driving, the engine runs cool and the temperature stays between 1/3 and 1/2 on the gauge (with outside temperature of 90 deg.).
Right now I'm suspecting overadvanced timing, since the engine runs well with the vac. advanced connected to manifold vacuum and the initial timing set at 15 deg. BTDC. Could overadvanced timing cause the engine to run warm at speed? Any other ideas that I can check out?
Thanks.
