Author Topic: Stealth Heads  (Read 2402 times)
Offline mickey
Stealth Heads
« on: August 26, 2008 - 11:34:04 AM »
Planning to purchase a set of Stealth Heads from 440 source bolt on out of the box, any comment or suggestions to make before i purchase them? GOOD/BAD ETC ..thxs
Offline moper
Re: Stealth Heads
« Reply #1 on: August 26, 2008 - 12:15:30 PM »
Worth the money, have them carefully inspected for retainer issues and the valve job checked. Same as anything else really.
Offline shawge
  • Zoiks!!
Re: Stealth Heads
« Reply #2 on: August 26, 2008 - 01:19:58 PM »
 :iagree:  I got the first run of heads from 440Source.  This is what my engine shop did:
- The keepers were crap and were replaced w/ 10* comp cams keepers & retainers (611-16 & 741-16.)  I've heard that the issues with the keepers have been fixed in the later runs.
- The push rod holes needed to be enlarged to support 3/8" push rods.
- Spring pressures were OK to use with a custom Engle K58 grind.
- Guides were honed and valves lapped.
That's it.  My 451 made 488 HP and 530 ft-lbs of torque on the dyno.
I'd call that good.  Just have your shop do an inspection on them to be on the safe side.
- Jerry
nivvy
Re: Stealth Heads
« Reply #3 on: August 26, 2008 - 02:00:43 PM »
fire ring overhangs into the combustion chamber.......  :working:
Offline shawge
  • Zoiks!!
Re: Stealth Heads
« Reply #4 on: August 26, 2008 - 02:13:26 PM »
On some heads, yes.  The engine builder is going to have to look at all the parts and do a select fit for any performance build.  Some folks have been successful in using the ROL (forget the #), Felpro 8519-PT or 17059 Marine gaskets.  For my engine, it was the factory chamfer that was causing the fire ring overhang problem and not the heads.  Solved by using MrGasket 3233G (4.500" MLS - made by Cometic.)
- Jerry
Offline moper
Re: Stealth Heads
« Reply #5 on: August 26, 2008 - 09:50:17 PM »
You want to be careful about the ring, but i understand that was the first batch of heads...
Offline mickey
Re: Stealth Heads
« Reply #6 on: August 26, 2008 - 10:18:04 PM »
Thanks folks, all responses grateful, makes my purchase so much easier. some concerns for sure. sounds like a pretty decent heads. cudachallenger ROCKS
Offline EB3-GranCoupe
  • BP23 U0B
Re: Stealth Heads
« Reply #7 on: August 11, 2009 - 09:00:59 PM »
mickey,
did you get the heads?  if so, how did they work?
thanks!
Offline Tejas R/T
Re: Stealth Heads
« Reply #8 on: August 12, 2009 - 09:56:29 PM »
 :popcorn:
Offline moparmaniac59
  • Drive it like ya stole it!
Re: Stealth Heads
« Reply #9 on: August 13, 2009 - 08:54:30 PM »
I am using the later production run Stealth heads with Hughes rockers and shafts, and different springs, keepers, retainers. Had them fully ported and slapped them on a 543 stroker that made over 600HP on the dyno. I've had no problems with them. Now I need a Dana 60!!
                                                Matt B.
Matt
moparniac
Re: Stealth Heads
« Reply #10 on: August 14, 2009 - 02:03:34 PM »
I wouldnt touch stealth heads with a ten foot pole.....  :poopoke: unless you had jeff at MCH do your heads for you... Worst customer service in the world!  :2cents:
Yes on the dana 60  :bigsmile:
Offline oldkimmer
Re: Stealth Heads
« Reply #11 on: August 15, 2009 - 02:58:35 PM »
..........Save yourself the money and agrevation...........ebrocks or indys ez .......kim...
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
Offline ragtopdodge
Re: Stealth Heads
« Reply #12 on: August 15, 2009 - 05:24:45 PM »
And THOSE heads has never had issues??? :stirpot:
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline moper
Re: Stealth Heads
« Reply #13 on: August 17, 2009 - 11:42:47 AM »
What they are screaming for is...
More Cowbell...
Offline Skeletoil
Re: Stealth Heads
« Reply #14 on: August 24, 2009 - 05:11:47 PM »
Bought the 543-1/2 inch stroker kit too. Heads were $900 bucks with the stroker kit it came in at $3000. Takes another $3000 to start. Oil pan, external oil lines, Msd ignition, rebalancing and checking, valves undercut. Main and head studs, main girdle, swinging oil pump pickup nothing that I can't do at home except the valve undercut. New retainers and springs to match the cam, steel washers for the springs and a good set of roller rockers and shafts and shims. Yah it will take another 3 grand.
