Author Topic: what is my rad support coming from?  (Read 2526 times)
Offline willard
    • 1970 Challenger R/T
« on: August 26, 2008 - 03:26:11 PM »
My chally is said to be # matching but the only stamped sequence that I found on the radiator support does not match VIN. See enclosed pics.
So is it a support from another car or maybe there are several #s stamped on the support and I missed the one I should look for?
The one on the picture was o the front, passenger side.
1970 383 R/T SE
Offline 71ChallengerSE
Re: what is my rad support coming from?
« Reply #1 on: August 26, 2008 - 04:07:28 PM »
looks like a part number to me not a sequence number, should be on drivers side :clueless:
Offline willard
« Reply #2 on: August 26, 2008 - 04:13:39 PM »
Definitely no other # on the outside (towards the bumper). Even if it was stamped from the inside, there should be an illegible mark on the other side. Anyone can posta picture of that #? Was it always on the drivers side?
ps
Sorry if it is an obvious question.
1970 383 R/T SE
Offline cudaguy71
« Reply #3 on: August 26, 2008 - 04:17:40 PM »
it might be on the inside and the radiator may hide it.
1973 'Cuda Project
1971 'Cuda Project
1998 Dodge Ram 1500
2003 Dodge Dakota Sport
1979 Plymouth Arrow
« Reply #4 on: August 26, 2008 - 04:21:11 PM »
This picture was taken upside down
« Last Edit: November 02, 2008 - 08:18:15 PM by 71ChallengerSE »
Offline hemiken
« Reply #5 on: August 26, 2008 - 04:22:52 PM »
The number is stamped on the top of the rad support as shown in the picture above. :2thumbs:
Offline 73Chally
« Reply #6 on: August 26, 2008 - 05:13:36 PM »
 :iagree: The number you are looking at might be a part number?  The VIN sequence should be stamped on the top driver side of the core support.  It could be illegible under several layers of paint if you don't see anything obvious.
« Reply #7 on: August 26, 2008 - 05:17:56 PM »
look between the radiator and the support, thats where mine was
Offline dutch
« Reply #8 on: August 26, 2008 - 05:27:43 PM »
I didn`t find it till I removed the paint...the numbers were not deep...
*** Bart ***
Alaskan_TA
« Reply #9 on: August 26, 2008 - 10:47:59 PM »
The radiator support VIN number location had no "set" specific place.
Most are found either on the top or back side, from the midline of the car to way over by the battery.
I have seen some that were hidden below the radiator coolant sticker as well, so feel for bumps under it.
If you do not find a number at all, it may have been hit & repaired before. They used to sell the complete radiator support as an assembly for collision repair.
Offline willard
« Reply #10 on: August 27, 2008 - 10:27:07 AM »
The previous owner says 'it is there":
Quote
The front rediator support is stamped in the inside ofr the front.You can see it best if tr radiator is removed but you can see it by looking down underneath the top rail inside.
but couldnt find it...
1970 383 R/T SE
Offline hemi71
« Reply #11 on: August 29, 2008 - 08:20:38 PM »
See the pic below. This is where you will usually find the VIN stamped in the radiator support..either on the top flange, or on the side facing the radiator.
Offline willard
« Reply #12 on: August 30, 2008 - 04:04:24 AM »
Will check it when the car comes back from customs depot. I'm 90% sure I closely inspected the marked areas but found nothing  :(
1970 383 R/T SE
Offline hemi71
« Reply #13 on: August 30, 2008 - 09:38:19 AM »
My superrbird had the numbers covered by a thin layer of bondo (for what reason I'll never know as the radiator support was never hit) and you could not see them until a later owner restored the car and the numbers were uncovered.
