Author Topic: Cuda what is the widest tire on 10 in rim and how much back spacing  (Read 6982 times)
Offline Cuda Dave
 :stomp:  will a275/60/15 on a 10in rim and 4 inches of back spacing fit on a 71 Cuda???Or what is the bigest tire I can run wih the least amount of back spacing I like that real deep back wheel LOOK.Thanks Dave.
Offline 360 'CUDA
Re: Cuda what is the widest tire on 10 in rim and how much back spacing
« Reply #1 on: August 26, 2008 - 07:02:33 PM »
In a word
no
I believe that would rub on the wheelwell lip.  At least on the driver's side
(and you need to fix your poll.  it just says fit fit)
« Last Edit: August 26, 2008 - 07:04:23 PM by 360cuda »
« Reply #2 on: August 26, 2008 - 07:21:43 PM »
I'm sure that size tire would work on an 8" rim.
Offline 6packCuda
« Reply #3 on: August 26, 2008 - 09:56:58 PM »
I have 275/60s on an 8 inch rim with 4 1/2" bs on my Cuda, and it's tight on both sides of the tire. I think the 10 inch rim would rub with no suspension mods.
« Last Edit: August 26, 2008 - 09:58:43 PM by 6packCuda »
Offline GoodysGotaCuda
« Reply #4 on: August 27, 2008 - 08:36:25 AM »
I ran 275/60/15s with 4" backspacing, 15x8 and was forced to get some super stock springs to keep the tires off the 1/4s. I run 295s on 18x9s now with no modifications (stiffer sidewall)
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #5 on: August 28, 2008 - 07:01:43 AM »
 A 275 on a 10" rim will have a 12 inch section width. Awfully wide there. Have you moved the springs at all?
Offline inviolet
« Reply #6 on: August 28, 2008 - 02:08:03 PM »
I'm a fan off stiff side walls too, I was looking to put a 18x10 on the rear with a 295/35. I haven't measured up any back spacing yet, but from the sound of things I may need to move the leaf spring. How about 18x9 1/2, do you think this will fit without suspension mods?
« Reply #7 on: August 29, 2008 - 09:25:52 PM »
May need a little 1/4 panel rolling if i did that on my car. (18x9.5)
1976 Dodge Warlock
Offline Aracer
« Reply #8 on: September 05, 2008 - 09:06:32 PM »
     On my 74 'cuda I rolled the wheel openings up, so the tires do not rub. In the past I used the 3,300 lb.SS's with the 340 and slicks, but since I replaced them with MP 440 Cuda springs and 440/727 auto. it rides 1.5" lower(or stock). The 275-60R x 15x8" with 4.5 offset, street tires do not rub either. A rear sway bar keeps it centered. Also,if you were to swap in a 1968 B body housing and offset rear shackles you would gain the room (3/4"each side) for the 10" x 5.5 offset rims. But then you would need the MP 3,600 lb. SS's for taller tires or slicks. A problem with the SS's is the shorter front segment, they will need longer front hangars, and although the hangars are thicker they are going to flex. Not the best for road racing, but adequate for the drags.
Offline Barracuda4
« Reply #9 on: September 05, 2008 - 09:22:32 PM »
My 74 has 8" rims with 275-60-15s in the rear.  I am using air shocks, but it won't rub.  No space to spare, but no rubbing.
'74 Cuda 360/727/ 8 3/4
Offline Aracer
« Reply #10 on: September 05, 2008 - 10:29:16 PM »
     Please don't use the air shocks, because they tear up the upper shock holes. :bigsmile:
Offline Barracuda4
« Reply #11 on: September 06, 2008 - 10:01:14 AM »
That would be bad...They aren't my first choice, but then again I ran them on every Mopar I had back in the 70's.  Maybe that's why they are so scarce today??   :smokin:
Offline IMNCARN82
  • LeDZeP
« Reply #12 on: September 06, 2008 - 10:16:27 AM »
Hey Dave,  :wave: There's a wheel/tire combo. section that might help.  :dunno:   I'd roll those quarters if ya' gotta'. I like the "stuffed look" too. Or mayby check out the "member rides" section.Just find a pic of one you like and go from there.     Hope the 'cuda is O.K.  :sadwavey:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline Carlwalski
« Reply #13 on: September 06, 2008 - 06:52:56 PM »
All cars vary. I have had a 275/60-15 on a 15x10 with a 5.5" BS on a 73 'Cuda. It fit but was very close. Close enough to be close but not close enough to worry. As I said, all cars vary so although it fit on my 73, it may not fit on Joe Blogg's 73. Cass @ Dr Diff said the differences are amazing. In all his years of springs, tires, disc brakes and rear ends he has come across hundreds of various setups and differences in factory cars. I believe it's 13" of room back there, with a 12" SW you'll be playing it close with 1/2" each side, that's too close for comfort, surely?
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
