Author Topic: What cutoff tool to use?  (Read 1094 times)
Offline ambitions2
  • ..we gunna make it to the finish line...
    • 72 Challenger EV-2 Project
« on: August 26, 2008 - 09:09:51 PM »
I was wondering what type of cutoff tool I should be using to cut the panels.  I have a Chicago 4" grinder with a cutoff wheel on it that is great, but I was wondering if I should be using a thinner or smaller diameter disk tool.  Thanks.
Project: 1972 Challenger - 340 AT 8 3/4 3.23 gears
http://community.webshots.com/user/jtitan2220
Offline Lunchbox
Re: What cutoff tool to use?
« Reply #1 on: August 27, 2008 - 03:00:52 AM »
I use a 3" on a die grinder. I like it becuase I can see what the heck is going on and the air power can be a little more forgiving at times.
Offline cudaguy71
« Reply #2 on: August 27, 2008 - 10:52:39 AM »
 :iagree:  Works great for me...
1973 'Cuda Project
1971 'Cuda Project
1998 Dodge Ram 1500
2003 Dodge Dakota Sport
1979 Plymouth Arrow
Offline shawge
  • Zoiks!!
« Reply #3 on: August 27, 2008 - 01:08:50 PM »
 :thumbsup: a die grinder w/ a thin cutoff wheel.
- Jerry
Offline dougs bs23
« Reply #4 on: August 27, 2008 - 04:28:38 PM »
use the 3" cutoff and for tight spots you can use cutoff wheels on your dremel tool but prepare yourself to go through lots of blades
Offline ambitions2
« Reply #5 on: August 27, 2008 - 05:26:59 PM »
I am currently look at a few die grinders.  I was reading about the review on WestCut discs due to their thin cuts, but I cannot find them anywhere to buy.
I will be using this for the floors pans, quarters, trunk and patches.
Thanks for the tips guys, after thinking about it it makes sense the 3" wheel and grinder would be easier to maneuver.
Should I be looking for one with high CFM?  High RPM?  Thanks a million guys, your helping me to learn.
Offline wally426ci
    • maryland mopars
« Reply #6 on: August 27, 2008 - 06:22:09 PM »
I used electric sheers on my 1/4's......
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Lunchbox
« Reply #7 on: August 27, 2008 - 06:29:27 PM »
I have two. One is a straight and use it for die grinding and cut off stuff. I bought it at harbor frieght for $10 works great and has lasted a long time. I also have a 90 deg craftsman that I use for grinding welds down. They both have thier place and wouldn't trade one for other.
Lunch
Offline ksierens
    • 70 Challenger Resurrection
« Reply #8 on: August 28, 2008 - 02:09:08 PM »
I use the 3M Green Corp cut off disks, I think the thinest ones are 1/32" or 1/16".  The cost more, but hold up a long time compared to the cheap ones.
http://www.autobodysupply.net/CUT-OFF-WHEEL-GREEN-CORP-3-X-1-32-X-3-8-p/3-m01989.htm
Kurt - SE Michigan
Offline Wang
  • "just hangin' out"
    • valleyautoworks.net
« Reply #9 on: August 28, 2008 - 05:15:27 PM »
f you are cutting a panel that is open on the backside,, consider a mini  air powered sawzall.  These things work great, cut MUCH faster than a
3" cutoff wheel, and with less heat (NO warpage).  You can use standard  hack saw blades, just cut them to the length you desire.  :2thumbs:
Hurry,, Duane the tub,,I'm Dwouning....
Offline Marty73
  • '73 Challenger
« Reply #10 on: August 29, 2008 - 02:58:13 PM »
I'm using a 4" Dewalt and metal cutting disc (chepo from Lowes), works great
Comin' at ya like a herd of turtles
