Author Topic: Scratches in the Glass of my door mounted rear view mirror...  (Read 783 times)
Offline elevenssc
« on: August 27, 2008 - 01:05:45 PM »
Does anyone have any suggestions on how to remove scratches in the glass on my pass rear view mirror?  I tried 2000 grit sand paper, but that made it worse.  Rubbing compound didn't seem to touch it.  Any suggestions will be appreciated.
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
Re: Scratches in the Glass of my door mounted rear view mirror...
« Reply #1 on: August 27, 2008 - 01:41:12 PM »
Try toothpaste.
Offline Slotts
« Reply #2 on: August 27, 2008 - 02:25:45 PM »
I've had pretty good success using 0000 steel wool. Real light circular rubbing and it does takes a while but it works on light scratches.
Slotts
Offline elevenssc
« Reply #3 on: August 27, 2008 - 08:01:18 PM »
Thanks...I'll give 'em both a try...
Offline cudadave72
  • you motorboatin sob!!!
« Reply #4 on: August 28, 2008 - 09:34:42 PM »
Slotts
0000 work great on regular glass but can destoy mirror glass which is much softer than tempered glass!!!! I would not go that route! Try a very light cleaner wax such a Meguires. Even toothpaste might be too aggressive. What ever you do be very careful! I hate to say it but you might have already gone too far. Good luck. :2thumbs:
« Last Edit: August 28, 2008 - 09:37:09 PM by cudadave72 »
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
« Reply #5 on: August 29, 2008 - 01:28:08 AM »
the silver is on the face of the mirror not behind it , you will need to replace the glass/ mirror
