Author Topic: W2's vs. Edelbrock RPM  (Read 45464 times)
nivvy
Re: W2's vs. Edelbrock RPM
« Reply #15 on: August 30, 2008 - 06:13:51 PM »
I was down at a friends today and he has a 1969 Dart 408 Stroker motor 435 HP I believe... the crate motor mopar sells... anyway he is thinking of selling the heads....  :working:
Offline 72bluNblu
« Reply #16 on: August 30, 2008 - 08:09:35 PM »
Sounds interesting to me, shoot me a Pm if he decides to, I'd be interested. Are they magnum heads?
Offline 71chally416
    • The Streetwalker
« Reply #17 on: August 30, 2008 - 11:40:39 PM »
If it's the 406/435 MP crate motor it has the iron 2.02 Intake valve Magnum R/T heads. Very similar ports and chambers to the Commandos. They're 406 cubes instead of 408 because they're .020" over blocks, not .030".
Offline 72bluNblu
« Reply #18 on: August 31, 2008 - 01:19:35 AM »
Now the magnums need a special valvetrain to go onto the LA blocks don't they? offset rockers or something?
« Reply #19 on: August 31, 2008 - 02:20:27 AM »
magnum heads oil through the pushrod so they need AMC lifters & hollow pushrods
Offline 72bluNblu
« Reply #20 on: August 31, 2008 - 02:24:56 AM »
Interesting...
« Reply #21 on: August 31, 2008 - 02:37:11 AM »
the rockers are not offset but they are Chev / Ball Stud style which I am not a fan of
nivvy
« Reply #22 on: August 31, 2008 - 03:52:29 AM »
says magnum on the valve covers and are 10 bolt valve covers.... he is supposed to get the info for me off the sheet that came with the crate... I believe he said they were swirl port also.....  I looked inside the 710 cap and it doesnt run a shaft sytem :working:
« Last Edit: August 31, 2008 - 03:54:00 AM by StRoKer »
Offline tactransman
« Reply #23 on: September 04, 2008 - 09:57:50 AM »
Here is a good article on the conversion http://www.moparts.org/Tech/Archive/smallblock/7.html
Terry-tactransman
Union, Mo.
Offline 72bluNblu
« Reply #24 on: September 04, 2008 - 01:04:04 PM »
Awesome! That'll make things easier if I go that route! :biggrin:
Offline 73challenger_TN
« Reply #25 on: September 04, 2008 - 04:05:23 PM »
:iagree: The 302's are the best stock based rocker shaft type heads to use if you can find a set, and they are much better with the right porting. The W-2's? 1980's technology. Back then they were the shizzle, but not so much today and they use ALL special parts and most use long stem valves. $$$$$$$
I Disagree about the 302 heads. Maybe on a 318 but j heads flow better.http://www.shadydellspeedshop.com/302.htm
If he changes his mind about those r/t magnums I might be interested.
Offline 71chally416
    • The Streetwalker
« Reply #26 on: September 04, 2008 - 07:26:36 PM »
There's more to heads than just total airflow. The chamber greatly affects tha motor's ability to make TQ, and the 302 chamber is much better than the J head.
Offline cudadave72
  • you motorboatin sob!!!
« Reply #27 on: September 09, 2008 - 03:46:53 PM »
I hate to jump in this late but I am more than pleased with the Edelbrocks on my car. Sure I know there is more power in a set of Indys, which is a plan for down the road, but my car makes great power with zero problems! Just my 2 cents!! :2thumbs:
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline 72bluNblu
« Reply #28 on: September 09, 2008 - 05:21:04 PM »
Thanks Dave!  :2thumbs:
Seems to me the edelbrock heads are pretty good for a bolt on and go operation. Definitely better heads out there, but they seem well suited to a street and occasional strip car that needs to retain some reliability.
Offline 71chally416
    • The Streetwalker
« Reply #29 on: September 09, 2008 - 06:19:32 PM »
The ED heads are OK to use stock on a smaller motor if you check the valveguide clearance before running them. I've heard that some come a bit too tight. They flow about like ported J heads the way they come.
For a bigger motor over 400 cubes, I don't think the Intake valves are big enough and the port volume is inadequate, unless you're happy with a short winded grunt TQ motor that throws the anchor out at 5,000rpm. At high RPM you get little more cylinder filling than what is contained in each cylinders port, so the bigger the motor is the more port volume is needed to feed the motor. That's obviously a different requirement for a 340 than it is for 416. Even the BB Mope engines like the old 413 have 2.08" Intake valves, and they're thought to be on the small side for anything bigger than a 383. A wedge head can only flow a finite amount of air with a 2.02" valve.
