Fuel pressure regulator need?
Author Topic: Fuel pressure regulator need?  (Read 2103 times)
Offline scf100
  • FAST LANE FOREVER!
« on: August 28, 2008 - 09:04:00 PM »
having problems with my car cutting off coming to a stop or putting in gear w/Eldo carb 650 avs...
see this thread
http://www.cuda-challenger.com/cc/index.php?topic=48434.0
I called the tech at Eldebrock and he said one of the things to check is fuel pressure( which I will check)  everything else on the carb has been gone thru...
I am running a stock 400 with 650 avs carb..........
are you guys all using a pressure regulator......what pressure should I have?
1970 Challenger R/T convertible 383…. 4-speed…3.91 suregrip
Triple Black
Offline 71chally416
    • The Streetwalker
Re: Fuel pressure regulator need?
« Reply #1 on: August 29, 2008 - 12:52:02 AM »
I use a Holley regulator set at 6psi with the Holley blue pump.
« Reply #2 on: August 29, 2008 - 01:49:19 AM »
4.5 is about the minimum pressure I would want to see
 not sure why you are running a 2 bbl on a 400 though
Offline scf100
« Reply #3 on: August 29, 2008 - 06:12:00 AM »
its a 4 barrel 650 cfm carb.......
I put a new stock fuel pump on trying to solve the prob and it didn't.....can a stock fuel pump vary that much in pressure?
« Last Edit: August 29, 2008 - 06:13:44 AM by scf100 »
Triple Black
« Reply #4 on: August 29, 2008 - 06:17:34 AM »
Before I would bother with a regulator, I would put a fuel pressure gauge in the line between the fuel filter and carb. My after-market hi-volume fuel pump was rated to be 6 PSI, but was closer to 9, ao I put a regulator on. I can't speak for the stock fuel pumps.
« Last Edit: August 29, 2008 - 06:19:17 AM by MEK-Dangerfield »
Offline scf100
« Reply #5 on: August 29, 2008 - 09:38:14 AM »
Mike, where did you end up putting the regulator?
Triple Black
« Reply #6 on: August 29, 2008 - 10:20:33 AM »
Just before my fuel pressure gauge. So the output of my fuel pump goes thru the fuel filter, regulator, fuel pressure gauge, then to the carb.
Offline Supercuda
« Reply #7 on: August 29, 2008 - 08:24:37 PM »
I put my pressure regulator right before the carb. The idea is to keep the higher pressure fuel as long as possible, only dropping the pressure when it is absolutely necessary. Definitely check your idle adjustments, including your speed. Also, Chryco's suggestion to check the pistons out while idling in gear, is a good one. All carburetors need adjustment in order to run on a Chrysler, so there is no such thing as true "bolt on" performance. Although Edelbrock carbs are more forgiving than Holleys when they aren't tuned, they will still work better when they are properly dialed in. The springs that control the metering rod position are an often-overlooked part of the carburetor's idle, main, and power circuits.
Offline vert
  • Looking good, Billy Ray! Feeling good, Louis!
« Reply #8 on: October 20, 2008 - 11:04:49 PM »
Nobody chiming in here about using a return-line regulator vs the dead-head regulator...?   Using this you have desired pressure at the carb without the pulsing action that a dead-head unit causes.  When line pressure exceeds the setting, the regulator opens, fuel continues to flow, and the excess is bled back to the tank via the return line.  Constant pressure at the carb, regardless of volume.  With a dead-head unit, as it throttles back pressure, it restricts volume as well.
71 Barracuda | Hemi idling | Hemi Dyno pull
Offline scf100
« Reply #9 on: October 21, 2008 - 10:13:15 AM »
my problem turned out to be a bad distributor..
Triple Black
Offline vert
« Reply #10 on: October 21, 2008 - 08:55:12 PM »
So it worked ut well for you.  Good.  What distributor did you go with?
Offline scf100
« Reply #11 on: October 21, 2008 - 09:22:18 PM »
got a stock electronic Mopar ditributor( my car has a 400 eng w/electronic ignition) from their restoration parts book for it...
Triple Black
