Will not crank?
Author Topic: Will not crank?  (Read 15278 times)
nivvy
Re: Will not crank?
« Reply #15 on: August 29, 2008 - 06:06:41 PM »
did you check the shifter manually under the car to make sure it was in park....  :working:
also you can take a screwdriver turn the key to on and arch the screwdriver on the big post on the relay under the hood and touch the small terminal posts to the left of the relay.... see if it starts :working:
« Last Edit: August 29, 2008 - 06:09:26 PM by StRoKer »
Offline old-school
Re: Will not crank?
« Reply #16 on: August 29, 2008 - 07:07:55 PM »
Yes it's in park and when i try to arc the relay it still does not crank.
Offline wally426ci
    • maryland mopars
Re: Will not crank?
« Reply #17 on: August 29, 2008 - 07:11:20 PM »
If your neutral safety switch is unhooked, you can ground that portion of the relay. Thats what i did..  :working:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline heminut
Re: Will not crank?
« Reply #18 on: August 29, 2008 - 07:12:18 PM »
Bad starter then. Arcing the relay takes everything else out of the picture, it even bypasses the neutral safety switch. Go ahead, ask me how I know! :scared:
1970 5.7 Hemi Cuda
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: Will not crank?
« Reply #19 on: August 29, 2008 - 07:31:16 PM »
heve you tryed to jump the relay with a screwdriver?
Go Fast & Have Fun...
Offline old-school
Re: Will not crank?
« Reply #20 on: August 29, 2008 - 08:31:19 PM »
Well, what's the consensus? Bad starter? I do not see any way that i can possibly get the starter out! The headers just aren't going to allow it. What do i do?
Offline NoMope Greg
Re: Will not crank?
« Reply #21 on: August 29, 2008 - 08:34:23 PM »
Unbolt the headers and move them out of the way.  And if you don't already have a ministarter, it's time to get one.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Re: Will not crank?
« Reply #22 on: August 29, 2008 - 09:37:41 PM »
if you don't hear the relay then the starter isn't the problem
Offline old-school
Re: Will not crank?
« Reply #23 on: August 29, 2008 - 11:07:55 PM »
When i turn the key to try to start the car, the relay does NOT make any sound and like i said before, it won't jump at the relay with a screwdriver either. I definately do not want to go through all of the trouble of pulling the starter if i don't have to.
« Last Edit: August 30, 2008 - 07:04:01 AM by old-school »
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
Re: Will not crank?
« Reply #24 on: August 29, 2008 - 11:17:11 PM »
Offline old-school
Re: Will not crank?
« Reply #25 on: August 30, 2008 - 07:01:23 AM »
The relay will NOT jump with a screwdriver
Offline wally426ci
    • maryland mopars
Re: Will not crank?
« Reply #26 on: August 30, 2008 - 07:04:47 AM »
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline old-school
Re: Will not crank?
« Reply #27 on: August 30, 2008 - 07:29:09 AM »
Please explain what this will do for me in my situation. How will this tell me if i have a bad starter or some other problem?
    • THE DODGE BOYS
Re: Will not crank?
« Reply #28 on: August 30, 2008 - 07:47:31 AM »
Old school what two terminals are you jumping on your relay mounted on the firewall?
It should be the large one coming from the battery and the small one just under it going to the starter.
Do they spark when you jump them?
« Last Edit: August 30, 2008 - 08:06:28 AM by thedodgeboys »
Offline wally426ci
    • maryland mopars
Re: Will not crank?
« Reply #29 on: August 30, 2008 - 07:47:49 AM »
It bypasses the nuetral safety, so maybe thats the problem  :dunno:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
